Released version "Wild Media Server (DLNA) v1.55.2 (64-bit)
Locked
Update to 1.55.2
Wild Media Server (UPnP, DLNA, HTTP) v.1.55
1. Added device configurations:
  • "Oppo Player (DLNA, 16:9, 720x406)";
  • "Sony Network Media Player (DLNA, 16:9, 720x406)".
2. Added support for bookmarks on the media resources folders through navigation on the media device (in the bottom of the list of media resources is added the folder "Add Bookmark"), this feature can be off in the settings of the program (Settings - "Media-Resources" - Service - Folder "Bookmarks").
3. To the structure of the media resources added the folder "Bookmarks" and "Last Browse" (for each client device they own). In the folder "Last Browse" added links to the most distant folders that were selected in the process of the media device navigation. The folder "Last Browse" can be used to continue navigation, if the number of levels of navigation on the media device is limited.
4. Added ability to restrict access of client devices to media resources by rating in stars and the color system parental control (http://en.wikipedia.org/wiki/Motion_pic ... ing_system), can be used separately or together.
5. The main form of the program:
  • to the list of movies, music, photos added the column "Rating in stars" (set by using the "mouse"), "Parental Control" (the choice of values ​​from the context menu), setting the values ​​for the folder and all child items with pressing Shift.
6. Information about the client device:
  • added setting "The minimum rating in stars of media resources" and color system "Parental Control" (maximum value).
7. Settings - "Media-resources":
  • added the button "Parental control by default" (on the right of folder "My Computer") to call the form "Settings the parental control and rating in stars of media resources".
8. Settings - Devices:
  • added the button "Parental control by default" (in the settings of new devices) to call the form "Settings the parental control and rating in stars of media resources".
9. Settings - "Media-resources" - Service:
  • added the settings page for the folder "Bookmarks";
  • added settings to restrict access to folders "Transcoding" and "Sort Order" (using this setting, the folder can be turned off for individual client devices).
10. Added the properties of media resources:
  • mpAddDate - date of adding a media resource to the media database;
  • mpLastPlaybackTime - date of the last play of media resource;
can be used in scripts processing, grouping of media resources.
Re: Released version "Wild Media Server (DLNA) v1.55.1 (64-b
Update to 1.55.2
1. Settings - "Media-resources":
  • in the Folder list added the column "Exclude from the common scan", the swtching-on of this setting can be used for:
    • exclude certain subfolders from scanning;
    • removable disk drives;
    • infrequently updated folders.
    You can force scanning excluded folders (select a folder line and press the Scan button).
2. Navigation on the media device:
  • in each folder of music resources added the folder Single Track, can be used for playback of resources in the current folder as a single track. Turning off this feature in settings of program (Settings - "Media Resources" - Service - Folder "Transcoding").
3. Added the transcoding profile "Music (Single Track)".
4. Updated subtitles module (added support for mov-subtitles).
Re: Released version "Wild Media Server (DLNA) v1.55.2 (64-b
nokia_lumia_web.zip
(6.15 KiB) Downloaded 1022 times
2. Copy nokia_lumia_web.cfg to ?:\Program Files (x86)\Wild Media Server\Devices
3. Restart the program
4. Settings - Devices - choose a device - Type - "Nokia Lumia (Web, 800x480, Internet Explorer)"
Nokia Lumia 610/710/800/900/820/920 (probably other devices with Windows Phone OS)
Access to the server: http://server_ip_address:45357
nokia_lumia_dlna.zip
(3.57 KiB) Downloaded 1039 times
2. Copy nokia_lumia_dlna.cfg to ?:\Program Files (x86)\Wild Media Server\Devices
4. Settings - Devices - choose a device - Type - "Nokia Lumia (DLNA, 800x480, Linada)"
Locked
