Playing vob files directly or transcode(decode) makes no difference. VOB file 1 is played, VOB file 2 is skipped and 3 is played, 4 is skipped again. The error displayed is: videocodec not supported.
Playing the file with Power DVD on my PC plays the whole without any problem.
Any idea what the problem is or how this can be solved? Is it a "bug" in WMS?
Regards Erik
vob file video codec not supported
Re: vob file video codec not supported
Dear all,
The problem I discribe was solved, for this movie, by turning on the DVD-structure directory. The movie played correctly and al parts. But still this was not the solution for all movies. Some still skip VOB files.
Erik
Erik
If the device does not support any of the files, you can try playing with transcoding (the folder Transcoding)
