More and more is working great, but i have a few more questions!
1. Cuesheet support: Most of my music i have ripped as wavpack (or .ape or .flac) images with cuesheets! If i plaback these cuesheets, WDTV Live Player shows me all titles in the cuesheet and the imagefile too! How can i prevent, that the player shows the imagefile too! I am looking for a way, to exclude the image-file! e.g. "If there is a cuuesheet, then exclude the imagefile"!
2. Trancoding wavpack: Wavpack files here will be trancoded to .mp3/320kb! Is it possible to trancode them to .wav?
3. A small issue with one .mkv - file! .mkv is supported by WDTV live native, but this file will be transcoded! Can you tell me why?
Here is the MediaInfo of this file:
Allgemein
Complete name : D:\Movies\Erbarmungslos\Erbarmungslos.mkv
Format : Matroska
File size : 4,18 GiB
Duration : 2h 5min
Overall bit rate : 4 773 Kbps
Encoded date : UTC 2010-02-04 14:13:30
Writing application : gdsmux
Writing library : Haali DirectShow Matroska Muxer 1.9.355.21
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@Main
Format settings, BVOP : Ja
Format settings, Matrix : üblich
Codec ID : V_MPEG2
Codec ID/Info : MPEG 1 or 2 Video
Duration : 2h 5min
Bit rate mode : variabel
Bit rate : 4 102 Kbps
Nominal bit rate : 7 500 Kbps
Width : 720 Pixel
Height : 576 Pixel
Display aspect ratio : 16:9
Frame rate : 25,000 FPS
Standard : PAL
Resolution : 8 bits
Colorimetry : 4:2:0
Scan type : Interlaced
Scan order : oberes Feld zuerst
Bits/(Pixel*Frame) : 0.396
Stream size : 3,59 GiB (86%)
Title : MPEG-2
Language : Englisch
Audio #1
Format : AC-3
Format/Info : Audio Coding 3
Format profile : Dolby Digital
Codec ID : A_AC3
Duration : 2h 5min
Bit rate mode : konstant
Bit rate : 192 Kbps
Channel(s) : 2 Kanäle
Channel positions : L R
Sampling rate : 48,0 KHz
Video delay : -96ms
Stream size : 172 MiB (4%)
Title : AC3 2.0
Language : Deutsch
Audio #2
Format : AC-3
Codec ID : A_AC3
Duration : 2h 5min
Bit rate : 384 Kbps
Channel(s) : 6 Kanäle
Channel positions : Front: L C R, Surround: L R, LFE
Video delay : -96ms
Stream size : 344 MiB (8%)
Title : AC3 5.1
Language : Englisch
Text #1
Format : VobSub
Codec ID : S_VOBSUB
Codec ID/Info : The same subtitle format used on DVDs
Language : Englisch
Text #2
Format : VobSub
Codec ID : S_VOBSUB
Language : Deutsch
Best regards
Helios
