Uff. I have it.
I had empty transcoding profile and AVis were always transcoded.
I have changed this parameter to Movies(primary) and all is OK now.
With subtittles must be transcoded always, I understand. Subs are OK too.
MKV and subtittles ? I see nothing.
DVD
I have DVD - Ennio Morricone - Arena Concerto.
It has 3 audio tracks. - DTS 5.1, AC3 5.1 and AC3 2.0. In Mediaserver are these tracks recognized as DCA, AC3, AC3.
DCA(what is it ? I know only libdca as library from VLC) is not playing. I have dts as embedded, it has native support. It normaly plays,
as audio and as muxed with video too.
Thanks for answer
Ziova 505
Re: Ziova 505
Where do not you see? on the device or program?Foolproof wrote: ---------------
DCA is DTS.Foolproof wrote: DVD
DCA(what is it ? I know only libdca as library from VLC) is not playing. I have dts as embedded, it has native support. It normaly plays,as audio and as muxed with video too.
Re: Ziova 505
Enkódoval : libebml v0.7.7 + libmatroska v0.8.1
Video
Formát : AVC
Formát/ : Advanced Video Codec
Format_Profile : High@L4.1
Format_Settings_CABAC/String : Ano
Format_Settings_RefFrames/String : 4 frame
MuxingMode : Container profile=Unknown@4.1
CodecID : V_MPEG4/ISO/AVC
Audio
Formát : DTS
Formát/ : Digital Theater Systems
CodecID : A_DTS
Duration/String : 1mn 57s
Bit rate : 1 510 Kbps
Kanál(y) : 6 kanály
Text #1
Formát : UTF-8
CodecID : S_TEXT/UTF8
/ : UTF-8 Plain Text
Jazyk : Dutch
Text #2
Formát : UTF-8
Jazyk : English
Video is transcoded to mpeg2 704x406
Audio is transcoded to AC3 .I do not know why - DTS I have as embedded, Audio DTS is playing without conversion.
No one in matroska embedded subtittles stream is to see.
How can I set for audio of video files "Never transcoding" ?
Re: Ziova 505
Select configuration "WD TV Live HD Media Player (DLNA, 16:9, 720x406)", turn on mode "Use shorted (16 characters) identifiers media resources" (Settings-Device-Thumbnails, identifiers)Foolproof wrote:This is a sample of MKVCode: Select all
Enkódoval : libebml v0.7.7 + libmatroska v0.8.1 Video ID : 1 Formát : AVC Formát/ : Advanced Video Codec Format_Profile : High@L4.1 Format_Settings_CABAC/String : Ano Format_Settings_RefFrames/String : 4 frame MuxingMode : Container profile=Unknown@4.1 CodecID : V_MPEG4/ISO/AVC Audio ID : 2 Formát : DTS Formát/ : Digital Theater Systems CodecID : A_DTS Duration/String : 1mn 57s Bit rate : 1 510 Kbps Kanál(y) : 6 kanály Text #1 ID : 3 Formát : UTF-8 CodecID : S_TEXT/UTF8 / : UTF-8 Plain Text Jazyk : Dutch Text #2 ID : 4 Formát : UTF-8 CodecID : S_TEXT/UTF8 / : UTF-8 Plain Text Jazyk : English
Re: Ziova 505
Moment, I need only audio as original, video must be transcoded.
I have now default profil, but custom changed.
WD has native support for H.264
Re: Ziova 505
From device select original audio mode, transcoding profile "Movies (primary) - MPLEX", maybe it will workFoolproof wrote:Moment, I need only audio as original, video must be transcoded.
