DTS Audio
Re: DTS Audio
Ok, getting farther. It reads LPCM on the XMB of the PS3 but the only sound i get is pure static...
Re: DTS Audio
Normal sound or noise?gtp_98c wrote:Ok, getting farther. It reads LPCM on the XMB of the PS3 but the only sound i get is pure static...
Re: DTS Audio
Just pure white noise sound.... Its not the speakers humming, its actually sending out white noise.
Re: DTS Audio
http://www.wildmediaserver.com/test/sample.mkv - sample file with dts 5.1 - try to convert using mkv2vob (http://www.mkv2vob.com) and play without transcoding.
Re: DTS Audio
In the film with DTS audio i've converted the DTS in AC3
- Extract the DTS audio from the film with MkvExtract
- Using TranzGui to create 6 wav mono file
- With WAV to AC3 Encoder convert the 6 wav file into an AC3 file
- Insert the new AC3 audio into the film with mkvmerge and set it as default prymari audio.
with this system i've modifyed all my mouvies with DTS to AC3 audio and now everything work fine.
Re: DTS Audio
So you are seeing DTS on your reciever or are you just getting DD5.1?
Thx
Thx
Re: DTS Audio
Eugene, i used the MKV2VOB on the movie i had the issues with and it worked. I now get full DTS while using this product, awesome!!! Now one more question, i wonder by running my movie thru MVK2VOB does it degrade video quality at all? The movie was in MKV and now it is in mpg. By moving to mpg does that do anything?
Thx
Thx
Re: DTS Audio
If you do not choose transcoding video, the video remains the same, mpg - extension, the format is likely to MPEG Transport Stream. At Sample.mkv check failed?gtp_98c wrote:Eugene, i used the MKV2VOB on the movie i had the issues with and it worked. I now get full DTS while using this product, awesome!!! Now one more question, i wonder by running my movie thru MVK2VOB does it degrade video quality at all? The movie was in MKV and now it is in mpg. By moving to mpg does that do anything?
Re: DTS Audio
Never bothered to try that one since this worked for me.
Re: DTS Audio
i downloaded and played your sample mkv. It plays fine but it is not DTS audio. It just comes up as DD5.1 on the PS3 xmb as well as my receiver.
Thx
Thx
