Nice work, I was waiting a 64-bit version for a long time.
I'm facing problems with CoreAVC profile after upgrade.
With 32-bit version, everything went fine; when I upgraded to 1.50, the message "Stack overflow" was appearing at message log every time I tried to play a movie using CoreAVC.
Well, made some tests with profile and I realized that "Stack overflow" appears at message log when CoreAVC fails to parse input parameters.
I have a Sony TV which has the old known "aspect ratio" bug, many time ago I needed to add the "+ ' -vf "aspect=4:3"' workaround on my CoreAVC profile, that doesn't work on WMS 1.50 anymore.
Any suggestions? Thanks in advance. My current "Movies - CoreAVC" profile follows:
csInputParams = '-f rawvideo -vcodec rawvideo -pix_fmt yuv420p -s %dx%d -r %s -i "%s"%s -i "%s"';
function CheckResult(aResult: Integer; aRaiseException: Boolean = True): Boolean;
Result := aResult = S_OK;
if not Result and aRaiseException then
RaiseException(Format('Error (code: %x) - %s', [aResult, SysErrorMessage(aResult)]))
bMatroskaSource, bMpegTS: Boolean;
sAudioFormat, sCodecTag, sInputParams,
sAudioMediaMajorType, sAudioMediaSubType,
sVideoMediaMajorType, sVideoMediaSubType,
sReadVideoPipeName, sWriteVideoPipeName,
sReadAudioPipeName, sWriteAudioPipeName,
sTranscodingParams, sAudioPinName, sVideoPinName: string;
iAudioStreamNo, iAudioChannels1, iAudioChannels2, iAudioSampleRate, iAudioFormatTag,
iVideoWidth, iVideoHeight, iVideoCompression: Integer;
vCurrentPosition: Variant;
bMpegTS := SameText(mpFileType, 'mpegts');
bMatroskaSource := SameText(ExtractFileExt(mpFilePath), '.mkv');
TranscodingResult := False;
if mpIsoItem or mpDvdItem or mpBdItem then begin
if not CheckResult(WmsDirectShowAddResourceSource('ResourceSource')) then
Exit;
if bMatroskaSource then begin
if not CheckResult(WmsDirectShowLoadFilter('Filters\MatroskaSplitter.ax', // MPC - Matroska Splitter
'{149D2E01-C32E-4939-80F6-C07B81015A7A}', 'Source')) then
Exit
end else if not bMpegTS or not CheckResult(WmsDirectShowAddFilter('Haali Media Splitter (AR)', 'Source'), False) then begin
if not CheckResult(WmsDirectShowLoadFilter('Filters\MpegSplitter.ax', // MPC - Mpeg Splitter (Gabest)
'{DC257063-045F-4BE2-BD5B-E12279C464F0}', 'Source')) then
Exit;
if not CheckResult(WmsDirectShowConnectPin('ResourceSource', 'Source', 'Output', 'Input')) then
Exit;
end else begin
if not CheckResult(WmsDirectShowLoadFilter('Filters\MatroskaSplitter.ax', // MPC - Matroska Source
'{0A68C3B5-9164-4A54-AFAF-995B2FF0E0D4}', 'Source')) then
Exit
end else if not bMpegTS or not CheckResult(WmsDirectShowAddFilter('Haali Media Splitter', 'Source'), False) then begin
if not CheckResult(WmsDirectShowLoadFilter('Filters\MpegSplitter.ax', // MPC - Mpeg Source (Gabest)
'{1365BE7A-C86A-473C-9A41-C0A6E82C9FA3}', 'Source')) then
Exit;
if not CheckResult(WmsDirectShowSetFileName('Source', InputFileName)) then
Exit
iAudioStreamNo := mpAudioStreamNo;
if iAudioStreamNo = -1 then
iAudioStreamNo := 0;
WmsDirectShowGetPinName('Source', PINDIR_OUTPUT, sVideoPinName, MEDIATYPE_Video, 0);
WmsDirectShowGetPinName('Source', PINDIR_OUTPUT, sAudioPinName, MEDIATYPE_Audio, iAudioStreamNo);
end else begin
sVideoPinName := 'Video';
sAudioPinName := 'Audio';
WmsDirectShowSelectStream('Source', iAudioStreamNo, MEDIATYPE_Audio, WmsGetStreamID(stAudio, iAudioStreamNo));
if not CheckResult(WmsDirectShowGetMediaType('Source', PINDIR_OUTPUT, sAudioPinName,
sAudioMediaMajorType, sAudioMediaSubType, iAudioChannels1, iAudioSampleRate, iAudioFormatTag)) then
Exit;
if sAudioMediaSubType = MEDIASUBTYPE_WAVE_DTS then
sAudioFormat := 'dts'
else if sAudioMediaSubType = MEDIASUBTYPE_WAVE_DOLBY_AC3 then
sAudioFormat := 'ac3'
else if sAudioMediaSubType = MEDIASUBTYPE_AAC then
sAudioFormat := 'aac'
else if sAudioMediaSubType = MEDIASUBTYPE_MP3 then
sAudioFormat := 'mp3'
else
sAudioFormat := '';
if mpTimeStart <> '' then begin
vCurrentPosition := WmsTimeConvert(mpTimeStart) * 10000000;
if not CheckResult(WmsDirectShowSetPosition('Source', TIME_FORMAT_MEDIA_TIME, vCurrentPosition)) then
Exit;
// if not CheckResult(WmsDirectShowAddFilter('CyberLink H.264/AVC Decoder (TechnoTrend)', 'Video Decoder')) then
if not CheckResult(WmsDirectShowAddFilter('CoreAVC Video Decoder', 'Video Decoder'), False) and
not CheckResult(WmsDirectShowAddFilter('Microsoft DTV-DVD Video Decoder', 'Video Decoder')) then
Exit;
if not CheckResult(WmsDirectShowConnectPin('Source', 'Video Decoder', sVideoPinName, '')) then
Exit;
// WmsDirectShowProperties('Video Decoder');
if sAudioFormat = 'aac' then begin
if not CheckResult(WmsDirectShowAddFilter('ffdshow Audio Decoder', 'Audio Decoder')) then
Exit;
if not CheckResult(WmsDirectShowConnectPin('Source', 'Audio Decoder', sAudioPinName, '')) then
Exit;
// WmsDirectShowProperties('Audio Decoder');
if WmsCreateDualPipe(sReadVideoPipeName, sWriteVideoPipeName) and
WmsCreateDualPipe(sReadAudioPipeName, sWriteAudioPipeName) then begin
if not CheckResult(WmsDirectShowAddDump(sWriteVideoPipeName, 'DumpVideo')) then
Exit;
if not CheckResult(WmsDirectShowAddDump(sWriteAudioPipeName, 'DumpAudio')) then
Exit;
if not CheckResult(WmsDirectShowConnectPin('Video Decoder', 'DumpVideo', '', '', MEDIATYPE_Video, MEDIASUBTYPE_I420)) then
Exit;
if not CheckResult(WmsDirectShowConnectPin('Audio Decoder', 'DumpAudio', 'Out', '',
MEDIATYPE_Audio, KSDATAFORMAT_SUBTYPE_PCM)) then
Exit;
if not CheckResult(WmsDirectShowGetMediaType('Audio Decoder', PINDIR_OUTPUT, 'Out',
sAudioMediaMajorType, sAudioMediaSubType, iAudioChannels2,
Exit;
sAudioFormat := Format(' -f s16le -ar %d -ac %d', [iAudioSampleRate, iAudioChannels2])
end else begin
if not CheckResult(WmsDirectShowConnectPin('Source', 'DumpAudio', sAudioPinName, '')) then
Exit;
if sAudioFormat <> '' then
sAudioFormat := ' -f ' + sAudioFormat;
if not CheckResult(WmsDirectShowGetMediaType('DumpVideo', PINDIR_INPUT, '',
sVideoMediaMajorType, sVideoMediaSubType, iVideoWidth, iVideoHeight, iVideoCompression)) then
Exit;
WmsDirectShowGetFrameRate('DumpVideo', PINDIR_INPUT, '', mpFrameRate);
if CheckResult(WmsDirectShowPlay) then begin
sInputParams := Format(csInputParams, [iVideoWidth, iVideoHeight,
ReplaceStr(FormatFloat('0.###', mpFrameRate), ',', '.'),
sReadVideoPipeName, sAudioFormat, sReadAudioPipeName]);
sInputParams := '-ts ' + mpTimeStart + ' -muxpreload ' + IntToStr(WmsTimeConvert(mpTimeStart)) + ' ' + sInputParams;
sTranscodingParams := sInputParams + WmsTranscodingVideoParams(0, 0, 0, 0, True, False) + ' -vf "aspect=4:3"' +
' "' + OutputFileName + '"';
// ShowMessage(sTranscodingParams);
TranscodingResult := WmsTranscodingExecute('WMSMPEG', sTranscodingParams)
