Hi all
Sorry, I've done some searching but not sure of the answer to this one.
I have a very large number of ISO images that scan readily into the Images directory. However it is a flat directory structure. Hence I get a list a few hundred to sort through on my WD TV Live.
Is there any way for WMS to show images in a directory structure similar to Folders or Genres that I use successfully for single video files?
DVD image folder structure
Re: DVD image folder structure
Select the folder Collections - right click - "Add folder"
Title: Iso Images
Type: Dynamic (script)
click Script
Expression:
Ok - Ok
Title: Iso Images
click Script
Expression:
IsoImagesFolder: TWmsScriptMediaItem;
IsoImagesFolder := WmsFindMediaFolder(mfVideoIsoImagesItemID);
if IsoImagesFolder <> nil then
for i := 0 to IsoImagesFolder.ChildCount - 1 do
WmsDatabaseLinkFolder(IsoImagesFolder.ChildItems[i].ItemID,
FolderItem.AddFolder(IsoImagesFolder.ChildItems[i].Properties[mpiFilePath]).ItemID, False);
That's brilliant, thank you very much. That makes it much easier to navigate.
Presently, I will typically choose Cell 00 to watch the video within an ISO image.
The WD TV Live will play ISO images with menu navigation from 'Network Shares'; however I'm guessing media server protocols don't support mounting an ISO image in this manner?
Media servers provide access to any part of iso-file. Just no media players, that work with iso-file via http.bhwsyd wrote:That's brilliant, thank you very much. That makes it much easier to navigate.
