Movies won't start 1.08.4 upgrade
oskarq
Post by oskarq »
I don't know what happened.
After upgrade to 1.8.4 everytime I start a movie it starts loading then quit and looking for the next movie in the catalog.
I saw such acting when the file was missing but all files are OK and they were fine yesterday.
How could I fix it.
oskarq
Re: Movies won't start 1.08.4 upgrade
Post by oskarq »
oskarq wrote:I don't know what happened.
How could I fix it.
come on.
Come on...
Who installed it already and everything is fine.
Now after testing I see that I cannot play movies when files are located on the network.
Local files are played OK.
...yes network is fine and I can watch movies through the same laptop.
Visnet
Post by Visnet »
How could I fix it.
come on.
Come on...
I have installed 1.08.4 here. Everything seems to work ok, starting a movie works as expected.
Wim
oskarq
Post by oskarq »
Wim
that's good news.
Do you have resources from the local network or local PC?
Oskar
PS. In the meantime I removed WMS and install 1.8.2 and works fine.
Visnet
Post by Visnet »
So far all local, I missed that, looking mainly at your initial post...
I copied a simple video file to a network disk and added this file to WMS. It played without any issue here.
It was a movie though with no transcoding needed.
Wim
