m2ts - Create thumbnail failed
rommi
Post by rommi »
Hi
I have some m2ts AVCHD Lite video files created in my Panasonic DMC-TZ10
files play nice on samsung TV after change container to TS and ply OK on PS3 (native m2ts)
This is mediainfo for one....
Property name/value
- General
Complete name: C:\mkv\20101230(125527).m2ts
Format: BDAV
Format/Info: Blu-ray Video
File size: 25.0 MiB
Duration: 17s 411ms
Overall bit rate: 12.0 Mbps
Maximum Overall bit rate: 18.0 Mbps
- Video
Menu ID: 1 (0x1)
Format: AVC
Format/Info: Advanced Video Codec
Format profile: High@L4.0
Format settings, CABAC: No
Format settings, ReFrames: 1 frame
Frame mode: Frame doubling
Codec ID: 27
Duration: 17s 120ms
Bit rate mode: Variable
Bit rate: 11.4 Mbps
Maximum bit rate: 16.6 Mbps
Width: 1 280 pixels
Height: 720 pixels
Display aspect ratio: 16:9
Frame rate: 50.000 fps
Standard: NTSC
Color space: YUV
Chroma subsampling: 4:2:0
Bit depth: 8 bits
Scan type: Progressive
Bits/(Pixel*Frame): 0.246
Stream size: 23.2 MiB (93%)
- Audio
Menu ID: 1 (0x1)
Format: AC-3
Format/Info: Audio Coding 3
Mode extension: CM (complete main)
Codec ID: 129
Duration: 17s 184ms
Bit rate mode: Constant
Bit rate: 192 Kbps
Channel(s): 2 channels
Channel positions: Front: L R
Sampling rate: 48.0 KHz
Bit depth: 16 bits
Stream size: 403 KiB (2%)
- Text
Menu ID: 1 (0x1)
Format: PGS
Codec ID: 144
Duration: 16s 612ms
problem is:
Create thumbnail failed....
wild media server wants create thumbnail on this videos...again and again... and samsung TV freezes for a short time to list files.. again and again
1. it is possible create thumbnail for m2ts files..???
2. it is possible disable autocreate thumbnail on file if first autocreate failed ????
OK... Create thumbnail failed - I disable thumbnail.... but this is not simple :-)
go to file -> right click -> edit information -> uncheck Thumbnail -> OK
and on the same file
go to file -> right click -> edit information -> Thumbnail still checked.... :-)
3. its way to disable Thumbnails on file(s) or on all files on one folder (to the future added files)
thanks rommi
Re: m2ts - Create thumbnail failed
rommi wrote: I have some m2ts AVCHD Lite video files created in my Panasonic DMC-TZ10
Property name/value
- General
Format: BDAV
File size: 25.0 MiB
Duration: 17s 411ms
- Video
Menu ID: 1 (0x1)
Format: AVC
Codec ID: 27
Duration: 17s 120ms
Bit rate: 11.4 Mbps
Width: 1 280 pixels
Height: 720 pixels
Standard: NTSC
Color space: YUV
Bit depth: 8 bits
- Audio
Menu ID: 1 (0x1)
Format: AC-3
Codec ID: 129
Duration: 17s 184ms
Bit rate: 192 Kbps
Bit depth: 16 bits
- Text
Menu ID: 1 (0x1)
Format: PGS
Codec ID: 144
Duration: 16s 612ms
problem is:
Select "broken" files - right click - "Edit information" - click "Select thumbnail"
rommi
Post by rommi »
:-) Yes. this is right. But if I don't have any ???
my preferred solution is disable thumbnail...
in future version will by this bug (checked and unchecked thumbnail) corrected..??
Settings - Device - "Thumbnails, identifiers" - turn off "Video"
rommi wrote: in future version will by this bug (checked and unchecked thumbnail) corrected..??
This option simply turns off the display of thumbnail on this form, may be useful when navigating through the cards.
