viperflyer wrote:WMS has been a savior since it is the only one with a great support for S770 of all the servers I have tried so far (TVersity, and FUPPES) and Windows DLNA which has its own limitations. Since, S770 can only support FAT32 drives, we only have an option of using capable media server such as WMS to stream large HD mkv and BD ISO files. However, I have had poor luck with streaming ISO files as it starts to stutter 15 seconds into the video. Any help in streaming this smoothly would be really appreciated.
I have also experienced on and off luck with streaming various other formats. At times I see that mkv and mt2s files would play and at the other times they wouldn't.
Try update to version 1.08rc1 (
http://www.wildmediaserver.com/forum/vi ... ?f=3&t=792).
viperflyer wrote:
Also, I have been using CoreAVC as the transcoding profile since TSMuxer hasn't been working for me. Because of this probably, I am also not able to see the subtitles. Any help here as well would be great.
You must select a subtitle track in the main form of the program by right click or in the folder Settings (navigate through the folder "Transcoding")
viperflyer wrote:
I have WMS 1.07 (trial) installed on Win7 (64 bit) which is hard-wired to S770. If above two issues are resolved then I will most likely be buying licensed version of WMS and will be keeping S770 otherwise, would be looking for a better BD player or just a stand-alone HD media players.
In my experience, Sony players do not have enough capacity in the network mode of operation. HD content slows down even without transcoding. My advice - network HD media player.
