Hulu support
Hulu support
Will there be support for Hulu anytime soon...
Re: Hulu support
Hulu does not work outside USA, Hulu does not work via USA Proxy, Hulu does not work through the program, which supports Hulu. I do not know exactly when to support Hulu. If you know a program that supports Hulu over a slow (USA Proxy) connection to Hulu, please let me know.surfingsmurf wrote:Will there be support for Hulu anytime soon...
Re: Hulu support
Thanks Eugene for your hardwork and reply
What if I live in the US?
Re: Hulu support
You can use the program with support for Hulu.surfingsmurf wrote: What if I live in the US?
Re: Hulu support
Hey Eugene,
I tried adding hulu like this http://www.wildmediaserver.com/forum/vi ... p?f=3&t=36 and I'm getting video file cannot be played
Re: Hulu support
What link did you use?surfingsmurf wrote: I tried adding hulu like this http://www.wildmediaserver.com/forum/vi ... p?f=3&t=36 and I'm getting video file cannot be played
Re: Hulu support
I used http://www.hulu.com in the path and also this is how I currently watching hulu on my laptop too.
Re: Hulu support
hulu.com uses for video rdmp:// linkssurfingsmurf wrote:I used http://www.hulu.com
Re: Hulu support
Do I just replace rdmp with http protocol? I googled and couldn't find anything onhow to use rdmp protocol with hulu. Any help is appreciated.
Re: Hulu support
Everything is more complicated, I think you just need patience, but for now use the program with support for Hulu.surfingsmurf wrote:Do I just replace rdmp with http protocol? I googled and couldn't find anything onhow to use rdmp protocol with hulu. Any help is appreciated.
