If the padding value from all sides equal 0, WMS really does not add a frame border. This can not be changed for the Movies (primary), but you can change transcoding profile Movies (additional) - Settings - Transcoder - Profiles - Movies (additional) - Editdgat wrote:Thats weird then - the file types are all AVI regardless of the aspect ratioEugene wrote:For the server, no matter the content of media resources (i.e. TV shows), but its work may depend on it file type.dgat wrote: Problem now is the framing has no effect at all on any 16:9 programs (i.e. TV shows) - the frame is not in the transcoded files for these. I have set it to always scale but to no effect plus played with all sorts of sizes and profiles.
I guess I can live with this but it seems weird - there must be some logic behind it deciding not to frame these - I have even set my orig frame to be 4:3 to see if that forces it but to no avail.
if (iPadLeft > 0) or (iPadRight > 0) or (iPadTop > 0) or (iPadBottom > 0) then begin
sParams := sParams + Format(' -padleft %d -padright %d -padtop %d -padbottom %d -padcolor %s',
[iPadLeft, iPadRight, iPadTop, iPadBottom, WmsConvertColor(cfgTranscodingPadColor)]);
if cfgTranscodingFrameExists then
sParams := sParams + cfgTranscodingFrameParams;
Inc(iFrameWidth, iPadLeft + iPadRight);
Inc(iFrameHeight, iPadTop + iPadBottom);
