Sony W5500
sony w5500
Sony W5500
Post by sony w5500 »
Hi Eugene!
I use WMS For a long time and this program is one of the best !
we days ago i download a new movie MPEG2 - Ts video (blue ray).
Unfortunately when i looking in the Sony GUI i see a gray square.
This file is running very well at my PC.
Ill be happy to hear your suggestion because i checked everything and its seems fine to me.
Thanks for your help :ugeek:
Re: Sony W5500
sony w5500 wrote: I use WMS For a long time and this program is one of the best !
If you are using WMS long time, then try it for yourself to answer the question, it will be useful to other users, most of the problems associated with specific devices, I use other devices.
sony w5500
Re: Sony W5500
i tried everything i know all the changes that you suggest in other posts is fine with my WMS. but in that file instead of thumbnail at the Sony's gui i see just this gray square.
Andrey
Re: Sony W5500
Post by Andrey »
Is it possible that TV has a file size limit? What is the size of the file you are trying to watch?
sony w5500
Re: Sony W5500
HEY ANDREI
THANK YOU FOR YOUR ANSWER THE SIZE IS 8.8 G
IF THERE IS A LIMIT? IF THERE IS HOW I CAN SEE HD MOVIES ?
Andrey
Re: Sony W5500
Post by Andrey »
Try to split the movie into parts < 4GB. At least you can check if that's the case.
sony w5500
Re: Sony W5500
DO YOU HERE ABOUT THIS PROBLEM ? WHEN IM LOOKING AT THE GUI I SEE JUST GREY SQUARE . . . ILL TRY TO SPLIT THANKS FOR THAT ADVICE :)
Re: Sony W5500
sony w5500 wrote:i tried everything i know all the changes that you suggest in other posts is fine with my WMS. but in that file instead of thumbnail at the Sony's gui i see just this gray square.
The only problem in the thumbnail ?
sony w5500
Re: Sony W5500
no of course its not the only problem the file wont play.
but i download some split program and now the file is just 2.4g and its works. so there is a limit for files :( do you know how to change that limit ?
