Hello Eugene,
When I play Shoutcast internet television on my Sony Bravia the sound is choppy. On Playstation 3 it's fine. What can I do? Probably the sample rate must be changed. But how?
Shoutcast on Bravia
Re: Shoutcast on Bravia
Settings-Transcoder-Profiles-Internet-television-Editha100 wrote:Hello Eugene,
Min(cfgTranscodingAudioBitrate div 1000, 192),
That doesn't help. I think the transcoded format is not ok for the Bravia W5500. In the transocing console it says:
I think the problem has to do with the audio stream of 22050 samplerate. PS3 has no problem with that but Bravia has.
Raw-audio server found, nsv demuxer selected
packetizer_mpeg4audio packetizer: AAC channels: 2 samplerate: 22050
Sorry, did not pay attention to the sample rate This radio station ?ha100 wrote:That doesn't help. I think the transcoded format is not ok for the Bravia W5500. In the transocing console it says:I think the problem has to do with the audio stream of 22050 samplerate. PS3 has no problem with that but Bravia has.Code: Select all
Raw-audio server found, nsv demuxer selected packetizer_mpeg4audio packetizer: AAC channels: 2 samplerate: 22050
No these are tv stations. Playing just fine on PS3 but not on Bravia. Picture on Bravia is ok but sound is not. The format it's transcoded into must not be fine for the Bravia. How can I change the format the sound is transcoded into?
Settings-Transcoder-Profiles-Internet-television-Editha100 wrote:No these are tv stations. Playing just fine on PS3 but not on Bravia. Picture on Bravia is ok but sound is not. The format it's transcoded into must not be fine for the Bravia. How can I change the format the sound is transcoded into?
Transcoding audio settings can be changed in line
csVideoLanParams =
'"<VLC>" -Idummy --sout-keep --language=en --sout-ffmpeg-strict-rc --sout=#gather:transcode' +
'{vcodec=%s,vb=%d,fps=%s,width=%d,height=%d,scale=1,%saspect=%s,acodec=%s,ab=%d,channels=2,' +
' "<INPUT FILE>" --loop'; // vlc:quit
function GetAudioCodec(const aFileFormat: string): string;
if SameText(aFileFormat, 'ASF (Windows Media Format)') then
Result := 'wma2'
else
Result := 'mpga'
Can I change 'mpga' into something else for the audio like I had to change 'mpeg1' into 'ps' for the video to make it work on Bravia?
Maybe change samperate at 8000, 16000, 32000, 44100 ?ha100 wrote:Can I change 'mpga' into something else for the audio like I had to change 'mpeg1' into 'ps' for the video to make it work on Bravia?
http://wiki.videolan.org/Codec
Mpga with samplerate at 22050 works best but still not ok. Mp3 works too but mpga is better. No sample rate is 100%. Is there something else I can try?
If changes the sound settings does not help, you can do transcoding test, copy the test file in a directory of media resources, to try to play a resource with a profile transcoding Movies (primary), if no problems, then we can make a new profile with a double transcoding.ha100 wrote:Mpga with samplerate at 22050 works best but still not ok. Mp3 works too but mpga is better. No sample rate is 100%. Is there something else I can try?
