Where stores WMS the Media Information
Rainer_S
Post by Rainer_S »
I have a Folder Structur for every Movie. I have renamed some Movies,but on the TV Screen,there is the same old name. So i want to rebuild the media informations,but i dont know,where i can find it. first i tried to rename the movie and scan the media device again,but nothing happens. also a server restart does resolve the problem. Hope you can help me.
TV:Sony KDL 52W4500
Blu-Ray: Sony BDP S370
Sound: Denon AVR 1611
Re: Where stores WMS the Media Information
Rainer_S wrote: I have a Folder Structur for every Movie. I have renamed some Movies,but on the TV Screen,there is the same old name. So i want to rebuild the media informations,but i dont know,where i can find it. first i tried to rename the movie and scan the media device again,but nothing happens. also a server restart does resolve the problem. Hope you can help me.
List [Movies] - select a file - right click - "Edit information"
Rainer_S
Post by Rainer_S »
Thanks for the answer and i wish i could do that, but in the window, there is only the main structure to see,but no files.
TV:Sony KDL 52W4500
Rainer_S wrote:Thanks for the answer and i wish i could do that, but in the window, there is only the main structure to see,but no files.
Files usually on the right
Rainer_S
Post by Rainer_S »
Yes usually,
but thats the problem, the program does shows any files. After delete the complete database and wms cfg files, i get my folder structure and the files.
but after a rescan, the files don´t display.
I delete again the cfg files, and now i can see the files too.
TV:Sony KDL 52W4500
