I have a Folder Structur for every Movie. I have renamed some Movies,but on the TV Screen,there is the same old name. So i want to rebuild the media informations,but i dont know,where i can find it. first i tried to rename the movie and scan the media device again,but nothing happens. also a server restart does resolve the problem. Hope you can help me.
Where stores WMS the Media Information
TV:Sony KDL 52W4500
Blu-Ray: Sony BDP S370
Sound: Denon AVR 1611
Re: Where stores WMS the Media Information
List [Movies] - select a file - right click - "Edit information"Rainer_S wrote: I have a Folder Structur for every Movie. I have renamed some Movies,but on the TV Screen,there is the same old name. So i want to rebuild the media informations,but i dont know,where i can find it. first i tried to rename the movie and scan the media device again,but nothing happens. also a server restart does resolve the problem. Hope you can help me.
Thanks for the answer and i wish i could do that, but in the window, there is only the main structure to see,but no files.
- wms.JPG (41.21 KiB) Viewed 7101 times
TV:Sony KDL 52W4500
Files usually on the rightRainer_S wrote:Thanks for the answer and i wish i could do that, but in the window, there is only the main structure to see,but no files.
Yes usually,
but thats the problem, the program does shows any files. After delete the complete database and wms cfg files, i get my folder structure and the files.
but after a rescan, the files don´t display.
I delete again the cfg files, and now i can see the files too.
TV:Sony KDL 52W4500
