Panasonic Viera TX-P42G20E
J.T.K.
Post by J.T.K. »
I'm opening this topic because I spend a lot of nights by searching for good and working DLNA server for this TV. And after I found it (actualy the WMS is the best) I spent additional week for server configuration tuning. Now it is almost done (maybe you will find it useful).
panasonic_viera_tv_dlna_wide_1920x1080.zip
CFG profile for Panasonic TX-P42G20E
(2.56 KiB) Downloaded 6478 times
macma1
Re: Panasonic Viera TX-P42G20E
Post by macma1 »
Good work:)
I have question about support of wma and wmv because there are in section "Embedded file support" but I can find any information about this file types support in TX-P42G20E. I found that it support aac (not tested yet).
Are you able to play this file types without trancoding?
Regards,
Macma
thunder2005
Post by thunder2005 »
J.T.K. wrote:I'm opening this topic because I spend a lot of nights by searching for good and working DLNA server for this TV. And after I found it (actualy the WMS is the best) I spent additional week for server configuration tuning. Now it is almost done (maybe you will find it useful).
hello,
i work with a Panasonic TX-L37D28EW
and your file works fine on this model
thx
