Panasonic Viera TX-P42G20E
I'm opening this topic because I spend a lot of nights by searching for good and working DLNA server for this TV. And after I found it (actualy the WMS is the best) I spent additional week for server configuration tuning. Now it is almost done (maybe you will find it useful).
				- panasonic_viera_tv_dlna_wide_1920x1080.zip
- CFG profile for Panasonic TX-P42G20E
- (2.56 KiB) Downloaded 6479 times
Re: Panasonic Viera TX-P42G20E
Good work:)
I have question about support of wma and wmv because there are in section "Embedded file support" but I can find any information about this file types support in TX-P42G20E. I found that it support aac (not tested yet).
Are you able to play this file types without trancoding?
Regards,
Macma
						Good work:)
Regards,
Macma
				thunder2005
J.T.K. wrote:I'm opening this topic because I spend a lot of nights by searching for good and working DLNA server for this TV. And after I found it (actualy the WMS is the best) I spent additional week for server configuration tuning. Now it is almost done (maybe you will find it useful).
hello,
i work with a Panasonic TX-L37D28EW
and your file works fine on this model
thx
