This is to let you know that I'm working on an italian translation of the program.
I think that it will be ready in a week or so.
Libero
Italian translation
Re: Italian translation
Hi all,
Here it is a new version.
All main dialog have been translated. Minor corrections are still to be done.
If you find some error please post it.
Version 1.52 for WMS 1.04.7 Libero
In order to improve the translation I'm asking some help.
I cannot understand what's the difference between option 3,4,5,and 6 in loading a new localization file.
It seems to me that 3 is the same as 5 and 4 is the same as 6.
rsMainCollectionMovies appears when right clicking on favorites (not Collections)
rsMainCollectionMusic ... on favorites (not Playlist)
rsMainCollectionPhoto ... on favorites (not Album)
what is: "Files: Positioning (DLNA)|Positioning (DLNA) for local resources" and How it works ?
Libero
Libero
Open the file - opens the specified file, the changes are saved in the specified filelibero wrote:In order to improve the translation I'm asking some help.
Copying - current localizations (languages) removed, new localizations (languages) from the specified file
Addition (allowed duplicate localizations) - just adding localizations (languages) without verification of their existence
Update (leave current localizations) - adding localizations (languages) which no
Update (replace current localizations) - adding localizations (languages) which no, full replacement localizations (languages) which exists (error in english localization - "leave current translations")
Merge (leave existing translations) - adding localizations (languages) which no, adding translations which no.
Merge (load new translations) - adding localizations (languages) which no, replace translations which exists.
Difference between Update and Merge
Current localization
Item1
Item2
Item3
Loaded localization
New Item1
New Item2
After Update
New Item1
New Item2
After Merge
New Item1
New Item2
Item3
Type of folder "Favourites" is Collection, Playlist, Albumlibero wrote: rsMainCollectionMovies appears when right clicking on favorites (not Collections)
DLNA-description of resource contains positioning modes, which supports the server for this resource. If enabled "By position in file", then device can request resources from the specified position (in bytes). If enabled "By time", then device can request resources from the specified time position (in seconds or time format).libero wrote: what is: "Files: Positioning (DLNA)|Positioning (DLNA) for local resources" and How it works ?
Still miss this.Eugene wrote:
----Type of folder "Favourites" is Collection, Playlist, Albumlibero wrote: rsMainCollectionMovies appears when right clicking on favorites (not Collections)
I do not understand why if I right-click on "Collection" I have in the menu "Add collection" but not "Remove collection"
if I right-click on favorites I have in the menu "Remove collection" but not "Add collection".
it works the same for movies, music and phtoto.
Thanks for the rest. Now is clear.
Libero
New Translation file for version 1.08.04 attached
Just one note to Eugene. in the file there are two empty field in the translation, both of them should contain "MPEG4", I cannot set them: once filled they revert to blank upon reopening the translation tool.
Seems some sort of a bug.
- Italiano.zip
- (62.63 KiB) Downloaded 1598 times
Thanks, I will try to fix. Temporary fix: change the english translation (for example MPEG41).libero wrote: Just one note to Eugene. in the file there are two empty field in the translation, both of them should contain "MPEG4", I cannot set them: once filled they revert to blank upon reopening the translation tool.
P.S. error in rsNetPortBlocked
version updated (it was green on my PC, so I had not seen the error)
- Italiano.zip
- (62.63 KiB) Downloaded 1570 times
Here it is the new translation file for version 1.12.
Libero
Libero
- default.zip
- Italian translation
- (111.99 KiB) Downloaded 1481 times
Italian Translation update to version 1.50.1
Regards
Libero
Regards
Libero
- default.rar
- (117.2 KiB) Downloaded 1665 times
