Italian translation
Help other users and get free licenses Wild Media Server (UPnP, DLNA, HTTP)
libero
Italian translation
Post by libero »
This is to let you know that I'm working on an italian translation of the program.
I think that it will be ready in a week or so.
Libero
libero
Re: Italian translation
Post by libero »
Hi all,
Here it is a new version.
All main dialog have been translated. Minor corrections are still to be done.
If you find some error please post it.
Version 1.52 for WMS 1.04.7
Italian_1.52.zip
(114.27 KiB) Downloaded 1911 times
Libero
libero
Post by libero »
In order to improve the translation I'm asking some help.
I cannot understand what's the difference between option 3,4,5,and 6 in loading a new localization file.
It seems to me that 3 is the same as 5 and 4 is the same as 6.
rsMainCollectionMovies appears when right clicking on favorites (not Collections)
rsMainCollectionMusic ... on favorites (not Playlist)
rsMainCollectionPhoto ... on favorites (not Album)
what is: "Files: Positioning (DLNA)|Positioning (DLNA) for local resources" and How it works ?
Libero
libero wrote:In order to improve the translation I'm asking some help.
Open the file - opens the specified file, the changes are saved in the specified file
Copying - current localizations (languages) removed, new localizations (languages) from the specified file
Addition (allowed duplicate localizations) - just adding localizations (languages) without verification of their existence
Update (leave current localizations) - adding localizations (languages) which no
Update (replace current localizations) - adding localizations (languages) which no, full replacement localizations (languages) which exists (error in english localization - "leave current translations")
Merge (leave existing translations) - adding localizations (languages) which no, adding translations which no.
Merge (load new translations) - adding localizations (languages) which no, replace translations which exists.
Difference between Update and Merge
Current localization
Item1
Item2
Item3
Loaded localization
New Item1
New Item2
After Update
New Item1
New Item2
After Merge
New Item1
New Item2
Item3
libero wrote: rsMainCollectionMovies appears when right clicking on favorites (not Collections)
Type of folder "Favourites" is Collection, Playlist, Album
libero wrote: what is: "Files: Positioning (DLNA)|Positioning (DLNA) for local resources" and How it works ?
DLNA-description of resource contains positioning modes, which supports the server for this resource. If enabled "By position in file", then device can request resources from the specified position (in bytes). If enabled "By time", then device can request resources from the specified time position (in seconds or time format).
libero
Post by libero »
Still miss this.
I do not understand why if I right-click on "Collection" I have in the menu "Add collection" but not "Remove collection"
if I right-click on favorites I have in the menu "Remove collection" but not "Add collection".
it works the same for movies, music and phtoto.
Thanks for the rest. Now is clear.
Libero
libero
Post by libero »
New Translation file for version 1.08.04 attached
Just one note to Eugene. in the file there are two empty field in the translation, both of them should contain "MPEG4", I cannot set them: once filled they revert to blank upon reopening the translation tool.
Seems some sort of a bug.
Italiano.zip
(62.63 KiB) Downloaded 1836 times
libero wrote: Just one note to Eugene. in the file there are two empty field in the translation, both of them should contain "MPEG4", I cannot set them: once filled they revert to blank upon reopening the translation tool.
Thanks, I will try to fix. Temporary fix: change the english translation (for example MPEG41).
P.S. error in rsNetPortBlocked
libero
Post by libero »
version updated (it was green on my PC, so I had not seen the error)
Italiano.zip
(62.63 KiB) Downloaded 1814 times
libero
Post by libero »
Here it is the new translation file for version 1.12.
Libero
default.zip
Italian translation
(111.99 KiB) Downloaded 1710 times
libero
Post by libero »
Italian Translation update to version 1.50.1
Regards
Libero
default.rar
(117.2 KiB) Downloaded 1884 times
