panasonic l42d25 subtitle ?
get_up
Post by get_up »
I m using WMS with sony tv profile for my panasonic , , tried others like dlna profiles but Sony tv profile Works better.
I m playing almost all videos , but i cant see subtitles in MKV and VOB (DVDs) , whats problem ?
for VOB , i tried "Select Track" but didnt work !!
for MKV , when i try "Select Track" for subtitles , it slows down and cant watch MKV at all ,,
any help ..
thank you
Re: panasonic l42d25 subtitle ?
get_up wrote:I m using WMS with sony tv profile for my panasonic , , tried others like dlna profiles but Sony tv profile Works better.
any help ..
thank you
http://www.wildmediaserver.com/forum/vi ... p?f=3&t=27
The program can overlay subtitles (external and internal) with video transcoding only.
VOB-files is supported files, so without video transcoding. You need to choose playback via the folder Transcoding.
If your PC is not enough to transcode on the fly, you can use a pause or a pre-transcoding (http://www.wildmediaserver.com/forum/vi ... &f=3#p3301 - "Pre transcoding (media-resource)").
get_up
Post by get_up »
You mean to play a file from Transcoding Folder while choosing subtitle in that folder on my tv , i choose subtitle from transcoding folder and play it but nothing happens..
thanks anyway
The main form of program - List [Movies] - select a file - right click - Test transcoding - what parameters of transcoding ?
Maybe useful: Settings - Scanning - "Creating DVD-structure folders for DVD-directories"
get_up
Post by get_up »
Sorry , i wasnt at home this days ..
So i tested but dont now if im putting right things here :
this is while working on .. didnt wait until and cause it is big
this is first capture
Unfortunately, the parameters of transcoding on the second picture are cut off
get_up
Post by get_up »
This media player is the best one for panasonic vieras , if anyone configured SUBTITLE problem it would be good ,, Without subtitles almost all media files can be played ..but with subtitle they dont .
