I m using WMS with sony tv profile for my panasonic , , tried others like dlna profiles but Sony tv profile Works better.
I m playing almost all videos , but i cant see subtitles in MKV and VOB (DVDs) , whats problem ?
for VOB , i tried "Select Track" but didnt work !!
for MKV , when i try "Select Track" for subtitles , it slows down and cant watch MKV at all ,,
any help ..
thank you
panasonic l42d25 subtitle ?
Re: panasonic l42d25 subtitle ?
http://www.wildmediaserver.com/forum/vi ... p?f=3&t=27get_up wrote:I m using WMS with sony tv profile for my panasonic , , tried others like dlna profiles but Sony tv profile Works better.
any help ..
thank you
VOB-files is supported files, so without video transcoding. You need to choose playback via the folder Transcoding.The program can overlay subtitles (external and internal) with video transcoding only.
If your PC is not enough to transcode on the fly, you can use a pause or a pre-transcoding (http://www.wildmediaserver.com/forum/vi ... &f=3#p3301 - "Pre transcoding (media-resource)").
You mean to play a file from Transcoding Folder while choosing subtitle in that folder on my tv , i choose subtitle from transcoding folder and play it but nothing happens..VOB-files is supported files, so without video transcoding. You need to choose playback via the folder Transcoding.
thanks anyway
The main form of program - List [Movies] - select a file - right click - Test transcoding - what parameters of transcoding ?get_up wrote:You mean to play a file from Transcoding Folder while choosing subtitle in that folder on my tv , i choose subtitle from transcoding folder and play it but nothing happens..VOB-files is supported files, so without video transcoding. You need to choose playback via the folder Transcoding.
Maybe useful: Settings - Scanning - "Creating DVD-structure folders for DVD-directories"
So i tested but dont now if im putting right things here :
- this is while working on .. didnt wait until and cause it is big
- ccc.jpg (93.83 KiB) Viewed 50517 times
- this is first capture
- bbb.jpg (58.06 KiB) Viewed 50517 times
Unfortunately, the parameters of transcoding on the second picture are cut off
This media player is the best one for panasonic vieras , if anyone configured SUBTITLE problem it would be good ,, Without subtitles almost all media files can be played ..but with subtitle they dont .
