yes, on the sample file. It stays at 2%
Also got a different error when starting the server.
WTV support?
Re: WTV support?
At test transcoding ?schomar wrote:yes, on the sample file. It stays at 2%
Advice on imageschomar wrote: Also got a different error when starting the server.
Re: WTV support?
Yes,
right click - test transcoding - default device
status bar indicates 2% and tsmuxer window opens
Image in previous post is logfile status of server at startup
- Capture2.JPG (116.53 KiB) Viewed 6953 times
Re: WTV support?
I installed version 0.73, same proble, try update to 0.73.4 (http://www.wildmediaserver.com/forum/vi ... &f=3#p1623)schomar wrote:Yes,
Re: WTV support?
No joy - it works on my W7 system, but WHS gives the errors below
Re: WTV support?
Perhaps wtv-files supported Windows Server 2008.schomar wrote:No joy - it works on my W7 system, but WHS gives the errors below
You can also use pre-transcoding (remuxing) files (Settings-Processing)
