Is there a way to transcode the new W7 MediaCenter *.wtv format?
Any plans on supporting this?
Now that I got WMS working on WHS, it would be great being able to watch my recorded tv in wtv format without WHS decoding it first to wmv with a lot of quality loss.
WTV support?
Re: WTV support?
If you upload the sample file on rapidshare.com, then I will check what can be done.schomar wrote:Is there a way to transcode the new W7 MediaCenter *.wtv format?
Re: WTV support?
uploaded two sample recordings to rapidshare. I've sent download links to your support account.
thx for looking into this
Re: WTV support?
Thanks.schomar wrote:uploaded two sample recordings to rapidshare. I've sent download links to your support account.
I did a transcoding profile "Movies - DirectShow - WTV", unfortunately there are problems with audio transcoding, it will be possible to work the original sound.
2. Settings-Transcoder-Profiles - Load - wtv.cfg - "Clear current lists ? " - No.
3. Settings - "File types" - Add
File extension: wtv
MIME-type: video/wtv
Transcoding profile: Movies - DirectShow - WTV
If you use individual settings for the device is set for wtv-files should be added there too.
4. Scanning media-resource folders.
5. In list of wtv-files on right click mouse "Test transcoding".
6. If successful, play on TV
Profile was checked on Windows 7, I do not know, it will work on WHS.
Re: WTV support?
Thanks, followed all the steps, but the transcoding test gave an error.
Files are seen on my TV as well but cannot be viewed obviously.
- Capture.JPG (52.29 KiB) Viewed 11713 times
Re: WTV support?
On W7 or WHS ?schomar wrote:Thanks, followed all the steps, but the transcoding test gave an error.
Re: WTV support?
Both. On W7 the tsMuxer.exe window opens, but then it stops
Re: WTV support?
On sample files ?schomar wrote:Both. On W7 the tsMuxer.exe window opens, but then it stops
Re: WTV support?
http://www.wildmediaserver.com/forum/vi ... 1744#p1744schomar wrote:What do you mean?
