WTV support?
schomar
Re: WTV support?
Post by schomar »
yes, on the sample file. It stays at 2%
Also got a different error when starting the server.
Re: WTV support?
schomar wrote:yes, on the sample file. It stays at 2%
At test transcoding ?
schomar wrote: Also got a different error when starting the server.
Advice on image
schomar
Re: WTV support?
Post by schomar »
Yes,
right click - test transcoding - default device
status bar indicates 2% and tsmuxer window opens
Image in previous post is logfile status of server at startup
Re: WTV support?
schomar wrote:Yes,
I installed version 0.73, same proble, try update to 0.73.4 (http://www.wildmediaserver.com/forum/vi ... &f=3#p1623)
schomar
Re: WTV support?
Post by schomar »
No joy - it works on my W7 system, but WHS gives the errors below
Re: WTV support?
schomar wrote:No joy - it works on my W7 system, but WHS gives the errors below
Perhaps wtv-files supported Windows Server 2008.
You can also use pre-transcoding (remuxing) files (Settings-Processing)
Re: WTV support?
