Making streaming DVD Setup easier...
Locked
Re: Making streaming DVD Setup easier...
I think, features can be added in next version
JST200 wrote: I think this method could be coded, as all the data required to do this is available and the logic I mention above still works.
1. Settings - Processing - Add -
Name: Create DVD-Cell link
turn on "Button on the main form"
Script:
  CellItem: TWmsScriptMediaItem;
  sDVDTitle, sFilePath: string;
  CellItem := WmsCurrentMediaListItem;
  if (CellItem <> nil) and SameText(CellItem.Properties[mpiFilePath], 'DVDVIDEO.VOB') then begin
    sFilePath := CellItem.ItemParent.ItemParent.ItemParent.Properties[mpiFilePath];  //ifo-file
    sDVDTitle := ExtractFileName(ExtractFileDir(ExtractFileDir(sFilePath)));
    WmsDatabaseAddLink(mfVideoCollectionsItemID, 'DVD\' + sDVDTitle, CellItem);
    if FileExists(ExtractFilePath(sFilePath) + 'folder.jpg') then
      WmsFindMediaFolder(mfVideoCollectionsItemID, 'DVD\' + sDVDTitle).Properties[mpiThumbnail] := ExtractFilePath(sFilePath) + 'folder.jpg';
    WmsDatabaseAutoSave
Ok - Ok - Ok
2. Select "Cell 00 - 00:00:00 - ..." - click "Create DVD-Cell link"
JST200 wrote: I think I am going to have to learn Pascal (?).
JST200 wrote: So, how difficult would it be to amend the script so that rather than getting sFilePath (?) from manually selecting the required Cell, it automatically finds it itself from the manually selected DVD Title. Something along the lines of (note: please forgive my meta-coding - its a long time since I wrote any real code!! And as I nmention above, I don't know Pascal! :-) )
Maybe it will be a solution for you, but not for others :)
A little later I'll add a script for your algorithm (processing for "All Movies").
JST200 wrote:That's "Basicscript" as in Visual Basic? Perhaps I might have chance after all - though Object Oriented code was something else I didn't get into! I'm going to need some examples! :D
http://www.wildmediaserver.com/forum/vi ... p?p=86#p86
JST200 wrote: In your DVD example, are you saying that there is no one Cell that is identifed as the full movie?
Yes, TV programs, serials, karaoke, ...
Name: Creating DVD-links
Script:
  dtTimeLength, dtMaxTimeLength: TDateTime;
  i, j: Integer;
  CellItem, ChapterItem, MainCellItem, PartItem: TWmsScriptMediaItem;
  sDVDPath, sDVDTitle: string;
  if aItem.IsFolder and SameText(ExtractFileExt(aItem.Properties[mpiFilePath]), '.ifo') then begin
    MainCellItem := nil; dtMaxTimeLength := 0;
    for i := 0 to aItem.ChildCount - 1 do begin
      PartItem := aItem.ChildItems[i];
      if PartItem.IsFolder then
        for j := 0 to PartItem.ChildCount - 1 do begin
          ChapterItem := PartItem.ChildItems[j];
          if ChapterItem.HasChildItems then begin
            CellItem := ChapterItem.ChildItems[0];
            if SameText(CellItem.Properties[mpiFilePath], 'DVDVIDEO.VOB') then try
              dtTimeLength := StrToTime(CellItem.Properties[mpiTimeLength]);
              if dtTimeLength > dtMaxTimeLength then begin
                dtMaxTimeLength := dtTimeLength;
                MainCellItem := CellItem
            except end;
    if MainCellItem <> nil then begin
      sDVDPath := ExtractFileDir(ExtractFileDir(aItem.Properties[mpiFilePath]));
      sDVDTitle := ExtractFileName(sDVDPath);
      WmsDatabaseAddLink(mfVideoCollectionsItemID, 'DVD\' + sDVDTitle, MainCellItem);
      if FileExists(sDVDPath + '\folder.jpg') then
        WmsFindMediaFolder(mfVideoCollectionsItemID, 'DVD\' + sDVDTitle).Properties[mpiThumbnail] := sDVDPath + '\folder.jpg';
  AllMoviesFolder: TWmsScriptMediaItem;
  AllMoviesFolder := WmsFindMediaFolder(mfVideoAllMoviesItemID);
  if (AllMoviesFolder <> nil) and AllMoviesFolder.HasChildItems then begin
    WmsShowInformation('Creating DVD-links...');
    try
      for i := 0 to AllMoviesFolder.ChildCount - 1 do
        ProcessItem(AllMoviesFolder.ChildItems[i]);
      WmsDatabaseAutoSave
    finally
      WmsHideInformation
Ok - Ok - Ok
2. Click "Creating DVD-links"
JST200 wrote: I have one further question (though it seems churlish of me to even ask!), although all the Collection DVD Titles now have an associated Icon, they don't show on the TV. Is this a limitation of DLNA?
Maybe limitation TV. Information about the thumbnails transferred and displayed on other DLNA-players.
JST200 wrote:Maybe/probably. Is there a way to check?
Select the folder "All movies" - right click - "Edit title" - click "Select thumbnail"
JST200 wrote: Cells show an "Icon" on the TV - although one doesn't appear for the cell in WMS when you select "Edit Info" for it.
Edit info - "Create thumbnail" (requests from a device, the mode Cards - automatic)
As far as I know, Sony TV show thumbnails for folders, but probably it depends on the model or mode of TV.
manuonline
Post by manuonline »
WOW Great work!
Only one Question:
Can i Change the Language of Movie?
Locked
