wms and 2 TVs parallel ?
Posted: Sat Dec 18, 2010 9:44 am
by Manfred
Hello
Since 1 year wms runs very well with a Sony Bravia TV
Now, I plan to buy a second TV for my daughter (located in her own room)
if I buy a second licens of wms is it possible to see different movies on the Tvs simultaneous?
Asumming, that the performance of the PC ist sufficient.
best regards
Manfred
Re: wms and 2 TVs parallel ?
Posted: Sat Dec 18, 2010 9:56 am
Manfred wrote: Since 1 year wms runs very well with a Sony Bravia TV
Yes, it is possible. I recommend using the 15-day license for free (required the Device Code(s) -
http://www.wildmediaserver.com/device_registration.php).
4. If you do not have enough trial period to test the program or if you have already bought a license and want to test it out with another device, you can apply by mail info@wildmediaserver.com for a free activation code on 15 days.
