Re: upscaling
Posted: Wed Sep 22, 2010 7:35 pm
srinivas_av wrote:A general question, Is it possible for WMS To upscale a DVD video while transcoding for HDTV ?
Or is it already doing it if I choose Movies (Primary_1920x1080) profile?
Yes, the transcoding profile "Movies (Primary_1920x1080)" converts to frame size 1920x1080.
Re: upscaling
Posted: Thu Sep 23, 2010 11:52 am
srinivas_av wrote:Thank you for confirming.
Can you please also confirm that, upscaling would improve the picture quality ..right?
Quality will not be better, typically a media device make it (upscaling) better.
Re: upscaling
Posted: Fri Sep 24, 2010 7:55 am
srinivas_av wrote:Ok,
Is it possible for WMS, in the future to make it (picture quality) better while at the transcoding stage. I guess, I have enough CPU/memory/GPU power in my desktop which can be utilized. Again, not sure whether it is possible or not technically, just asking.
No, unfortunately, from 320x240 you can not do HD quality.
