Page 1 of 2
no longer access InternetTV after VLC upgrade
Posted: Thu Sep 02, 2010 2:03 am
by Isaac
I can no longer access any InternetTV stream. I checked the stream and it's still valid
http://99.198.118.250:8010;stream.nsv
When I right click, select 'Test Transcoding', 'Default Device' I get the following error
"C:\Program Files (x86)\Wild Media Server\wmsmpeg.exe" "C:\Program Files (x86)\V
ideoLAN\VLC\vlc.exe" -Idummy --language=en --sout-ffmpeg-strict-rc --sout=#trans
code{vcodec=mp2v,vb=8000,fps=24,width=720,height=576,scale=1,aspect=16:9,acodec=
mpga,ab=192,channels=2,samplerate=48000}:duplicate{dst=std{access=file,mux=ps,ds
t="C:\Users\zeek\AppData\Local\WILDME~1\WMS\Temp\Test_6d60cb881066043cf57a959c6a
eaa373.mpg"}} "http://99.198.118.250:8010;stream.nsv"
built on May 2 2010 17:40:51 with gcc 4.4.0
libavutil 50.13. 0 / 50.13. 0
libavcodec 52.61. 0 / 52.61. 0
libavformat 52.57. 1 / 52.57. 1
libswscale 0.10. 0 / 0.10. 0
Unable to find a suitable output format for 'C:\Program Files (x86)\VideoLAN\VLC
\vlc.exe'
Windows 7
Re: no longer access InternetTV after VLC upgrade
Posted: Thu Sep 02, 2010 7:18 am
Isaac wrote:I can no longer access any InternetTV stream. I checked the stream and it's still valid
\vlc.exe'
Windows 7
Settings - Transcoder - Profiles - "Internet-television" - Restore
Settings - Transcoder - Profiles - "Internet-television (Input stream)" - Restore
Settings - Transcoder - Profiles - "Internet-television (Remux)" - Restore
Posted: Fri Sep 03, 2010 2:44 am
by Isaac
Thanks Eugene, that worked.
Isaac
Posted: Sat Sep 25, 2010 10:37 pm
by Isaac
My audio is not working when viewing Internet TV links.
[021fcd84] dummy interface: VLC media player - 1.1.4 The Luggage
[021fcd84] dummy interface: Copyright c 1996-2010 the VideoLAN team
[021fcd84] dummy interface: using the dummy interface module...
[021d9b94] mux_ps mux: Open
[0256344c] access_http access: Raw-audio server found, nsv demuxer selected
[021f2474] packetizer_mpeg4audio decoder: AAC channels: 1 samplerate: 32000
[021fad94] main stream out error: Failed to create audio filter
[021fad94] stream_out_transcode stream out error: Failed to find conversion filt
er for resampling
[021fad94] stream_out_transcode stream out error: cannot create audio chain
[021f2474] main decoder error: cannot create packetizer output (mp4a)
Posted: Sun Sep 26, 2010 7:48 am
Isaac wrote:My audio is not working when viewing Internet TV links.
er for resampling
http://www.wildmediaserver.com/forum/vi ... 287e#p2588
Posted: Sun Sep 26, 2010 1:20 pm
by Isaac
That did not work for me, perhaps I misunderstood and applied the incorrect settings. Would you please check my work?
[0219cd84] dummy interface: VLC media player - 1.1.4 The Luggage
[0219cd84] dummy interface: Copyright c 1996-2010 the VideoLAN team
[0219cd84] dummy interface: using the dummy interface module...
[02179b94] mux_ps mux: Open
[02192474] packetizer_mpeg4audio decoder: AAC channels: 1 samplerate: 32000
[0219ad94] main stream out error: Failed to create audio filter
[0219ad94] stream_out_transcode stream out error: Failed to find conversion filt
er for resampling
[0219ad94] stream_out_transcode stream out error: cannot create audio chain
[02192474] main decoder error: cannot create packetizer output (mp4a)
Posted: Sun Sep 26, 2010 3:44 pm
Isaac wrote:That did not work for me, perhaps I misunderstood and applied the incorrect settings. Would you please check my work?
er for resampling
List [Movies] - select media-resource - right click - Transcoding profile - "Movies - VLC - FFMPEG"
Posted: Sat Oct 02, 2010 8:41 pm
by Isaac
Eugene wrote:List [Movies] - select media-resource - right click - Transcoding profile - "Movies - VLC - FFMPEG"
That does not work, when I test transcoding manually I'm prompted with a y/n.
Input #0, nsv, from '\\.\pipe\08FE3C71109A4AD0A248832C5DF0BD43':
Duration: 00:00:00.00, start: 0.000000, bitrate: N/A
Stream #0.0: Video: vp6, yuv420p, 320x240, 15 tbr, 15 tbn, 15 tbc
Stream #0.1: Audio: libfaad, 32000 Hz, 2 channels, s16, 38 kb/s
File 'C:\Users\zeek\AppData\Local\Wild' already exists. Overwrite ? [y/N]
Posted: Sun Oct 03, 2010 6:57 am
My transcoding folder not contains spaces, I made changes in script.
Posted: Thu Oct 07, 2010 12:01 am
by Isaac
Do you mean
Settings-Transcoder-Directory Temporary Files Path?
