Auto-updating collection?
Posted: Fri Feb 19, 2010 8:51 pm
by ogre111
Hi
First of all, thanks for the program, it's just great.
But I wanted to know, how a collection folder could automatically add videos to itself from a folder of my computer? For example, I made a collection named "Classical movies" and I have a folder called "Classical movies" on my computer. And when I add a movie to the folder on my computer, then it goes to the all movies and in the "Classical movies" collection.
I am not good at explaining things...
Re: Auto-updating collection?
Posted: Sat Feb 20, 2010 6:59 am
ogre111 wrote: But I wanted to know, how a collection folder could automatically add videos to itself from a folder of my computer? For example, I made a collection named "Classical movies" and I have a folder called "Classical movies" on my computer. And when I add a movie to the folder on my computer, then it goes to the all movies and in the "Classical movies" collection.
In version 0.72.5 added dynamically generated folder, you can use this feature. In the folder tree on the right mouse button "Edit title", select "Dynamic (script)", press button Script
  mfVideoWatchFoldersItemID = 'B7A1EE6A-CE07-4E09-B5ED-E51D22BBE743';
  iPathOffset: Integer;
  WatchFolder: TWmsScriptMediaItem;
function FindWatchFolder(aFolder: TWmsScriptMediaItem; const aTitle: string): TWmsScriptMediaItem;
  Result := nil;
  if (aFolder <> nil) and aFolder.HasChildItems then
    for i := 0 to aFolder.ChildCount - 1 do
      if aFolder.ChildItems[i].HasChildItems then begin
        if SameText(aFolder.ChildItems[i].Properties[mpiTitle], aTitle) then
          Result := aFolder.ChildItems[i]
        else
          Result := FindWatchFolder(aFolder.ChildItems[i], aTitle);
        if Result <> nil then
          Break
procedure ProcessFolder(aFolder: TWmsScriptMediaItem);
  Item: TWmsScriptMediaItem;
    for i := 0 to aFolder.ChildCount - 1 do begin
      Item := aFolder.ChildItems[i];
      if Item.HasChildItems then
        ProcessFolder(Item)
      else
        FolderItem.AddItem(Copy(ExtractFileDir(Item.Properties[mpiFilePath]), iPathOffset, 1024), Item)
  WatchFolder := FindWatchFolder(WmsFindMediaFolder(mfVideoWatchFoldersItemID, ''), 'Classical movies');
  if WatchFolder <> nil then begin
    iPathOffset := Length(IncludeTrailingBackslash(WatchFolder.Properties[mpiFilePath]));
    ProcessFolder(WatchFolder);
Click Renew in the main form of the program.
Posted: Sat Feb 20, 2010 7:40 am
by ogre111
Thanks for the quick reply.
I don't seem to get it working. I updated to 0.72.5, added a collection " Movies ", then "edit name" chose "dynamic script" , pressed "script", copied the code you sent and pressed ok. Then I made a folder " Movies " in my computer and added it to the media resources of the program.
I renewed it, closed the program and started again, but nothing seems to work.
No files seem to appear in the collection.
