Sound goes demonic after playing video for some time
Posted: Tue Feb 16, 2010 10:11 pm
by SNiLD
After playing some videos the sound of them goes demonic (usually right after scene changes). If I replay the same file that has been saved by WMS for pre-transcoding the same happens. If I replay the original file with Media Player Classic Home Cinema there is no problem.
Re: Sound goes demonic after playing video for some time
Posted: Wed Feb 17, 2010 7:27 am
SNiLD wrote:After playing some videos the sound of them goes demonic (usually right after scene changes). If I replay the same file that has been saved by WMS for pre-transcoding the same happens. If I replay the original file with Media Player Classic Home Cinema there is no problem.
You can upload an example of a problem file to rapidshare.com and specify the time of the problem?
Posted: Wed Feb 17, 2010 9:16 pm
by SNiLD
Eugene wrote:You can upload an example of a problem file to rapidshare.com and specify the time of the problem?
The resulting and original files are waaaaaay too big to be uploaded anywhere. The file it generates (d5eb16bddf328700c2dbde9ea768c28e.mpg) is 2,33GB and I was unable to cut it at all. This file is generated by WMS from "24.s08e01.720p.hdtv.x264-immerse.mkv". Maybe you can find it from alternative sources? It's 1,09GB. The sound turns demonic after 23:55.
Posted: Fri Feb 19, 2010 7:44 am
SNiLD wrote:Eugene wrote:You can upload an example of a problem file to rapidshare.com and specify the time of the problem?
The problem exist, with what is related, I do not know, when the test transcoding is no errors. Helps the choice playback from 25 minute through a folder Transcoding (setting intervals start playing - Settings-Media-Resources-Service)
