Page 2 of 2
Re: Watch TV Channels (dvb-s) on a upnp Client
Posted: Tue Jun 08, 2010 4:57 pm
pucapg wrote:
wehere can I check the playback in windows?
When I clicked on the DVBVIDEO.ts in the Server and choose the VLC Media Player, nothing happens. And when I double click on the WMS Server over the Network and the Windows Mediaplayer was opend, I cant choose the TV channels, I only can watch the Videos and here the music from the server.
Usually with DVB-card comes DVB-Player. If there is no DVB-player, you can find it on the Internet.
pucapg wrote:
And where can I select the transcoded format file? When i right click on the type video from the dvbvideo.ts and than choose edit information, I nothing found a menu where can I select the mpeg (dvd).
Settings-Transcoder-"Codecs,frame"-File format.
Posted: Wed Jun 09, 2010 7:46 pm
by pucapg
thanks for your help at first.
Yes the TV Card has a own program to show the tv channels. And there is no problem, the TV channels which I tryed to watch over the streaming client can I watch without any problems over the TV programm from the tv card.
The transcoder file format was always mpeg (DVD), and there were the problems.
But I also switch to mpeg ts and the 3 rd file format but with the same effect.
I told you before that the cpu processor load was 40 to 50 %, this processor load need the server program, but the total cpu processor load, when i try to watch the tv channel over the streaming client is 100 %, when i watch the one tv channel which I can watch over the streaming client there are 65 total cpu processor load.
So what can I do to watch all tv channels on the streaming client, is it possible that the computer is to slowly?
Richard
Posted: Thu Jun 10, 2010 5:30 pm
In the list of channels on the right mouse button you can load file properties. What video encoding?
If the video encoding MPEG2, via folder "Transcoding" you can select a mode "Original video" in folder Settings. File format should be MPEG (DVD). This will reduce the CPU load.
Posted: Fri Jun 11, 2010 3:46 pm
by pucapg
Hello, thanks for your answer at first.
I load the file properties but i can t find "video encoding" the video codec is mp3 Audio codec mp2.
Than in settings -> Transcoding -> codec, frame, I can choose Video Format mpeg2 (is selected) or wmv, no "Original Video".
So did i have not the chance to select "Original Video" and reduce the cpu load or where is the menu to select this?
Richard
Posted: Fri Jun 11, 2010 7:49 pm
by pucapg
Here are the infos from the dv piper when I try to watch a tv channel over the streaming client.
Richard
Posted: Sat Jun 12, 2010 4:39 am
Are you sure, mp3 ?
pucapg wrote:
Than in settings -> Transcoding -> codec, frame, I can choose Video Format mpeg2 (is selected) or wmv, no "Original Video". So did i have not the chance to select "Original Video" and reduce the cpu load or where is the menu to select this?
Navigation on Media Device.
Folder Transcoding - DVB - choose Channel, Settings - Original Video on
In parameters of Test Transcoding must be -vcodec copy
Posted: Mon Jun 14, 2010 6:58 pm
by pucapg
Hello, thanks for your reply.
I have to say sorry, the video codecs when i load file properties is MPEG2VIDEO.
When I go in the folder "Folder Transcoding - DVB - choose Channel, Settings - Original Video on",
I can't test transcoding because the message "Transcoding is not supported" comes, when i try this.
I donet know how I can choice the in parameters from test transcoding.
However I used a other computer a dual core Pentium with 2,4 GHz and 2 GB RAM.
There is the cpu load 30 % for the hole system.
At first when i searched the first 6 tv channels, and than try to watch this channels on the media client it works very well.
Than i searched longer for more channels, wildmediaserver found 64 tv channels, than i abort the search.
But the progam found the first 6 channels over other search parameter, so that the 60 tv channels are 6 tv channels because the other are a double of the first 6 tv channels.
I try to watch this channels over the media client and than there was a distorted video, but better than with the other computer.
I dont know but between the first and the second tv channel search came this problem.
I do than the test transcoding from a tv channel, the result you can see in the picture.
Can you help me?
thanks Richard
Posted: Tue Jun 22, 2010 7:32 pm
by pucapg
so now it works with a dual core computer and the Technisat Sky Star USB HD TV Card with a few tv channels,
the rest I will see,
thanks for your help.
Richard
