Is there an embedded function to generate UNIX time – seconds that have elapsed since midnight, January 1, 1970?
Regards.
						UNIX time function?
Re: UNIX time function?
coarse variant (with LocalTimeOffset)
DateTimeToTimeStamp1970(Now)
function TimeStamp1970ToDateTime(aTimeStamp: Integer): TDateTime;
  Result := (aTimeStamp / (24 * 60 * 60)) + EncodeDate(1970, 1, 1)
function DateTimeToTimeStamp1970(aDateTime: TDateTime): Integer;
  Result := Round((aDateTime - EncodeDate(1970, 1, 1)) * 24 * 60 * 60)
				S@gittarius
Hi,Eugene wrote:Hi,
DateTimeToTimeStamp1970(Now)Code: Select all
function TimeStamp1970ToDateTime(aTimeStamp: Integer): TDateTime; begin Result := (aTimeStamp / (24 * 60 * 60)) + EncodeDate(1970, 1, 1) end; function DateTimeToTimeStamp1970(aDateTime: TDateTime): Integer; begin Result := Round((aDateTime - EncodeDate(1970, 1, 1)) * 24 * 60 * 60) end;
Thank you for your assistance.
I was thinking about something similar and before seeing your answer I came up with the following:
function DateTimeToUnixTimestamp(dtValue: TDateTime): integer;
    iGMTOffset = 2;   // GMT +2
    h, m, s, ms: integer;
    DecodeTime(dtValue,h,m,s,ms);
    Result := Int(dtValue - EncodeDate(1970, 1, 1)) * 86400 + (h - iGMTOffset) * 3600 + m * 60 + s;
  end;For now I haven’t thought about the reverse function but if I come up with something new I’ll posted it.
Regards
