I can not set up any Internet-radio
ramaral
Contact:
Post by ramaral »
Hi Eugene.
Can you help me with this?
I can not set up any Internet-radio.
I've tried this:
Folder "Internet-radio" - List [Music] - right click - Add Link - Path: http://85.25.130.71:9096 - Ok - right click - Transcoding profile "Music - Internet-Radio (VLC)"
but, at TV, i get the error: File not found
I tried other options but without success.
Re: I can not set up any Internet-radio
I've tried this:
Have you tried the radiostations from iTunes (without VLC) ?
ramaral
Contact:
Post by ramaral »
No, i do not use itunes. Why do you ask this?
These are examples of radio station what I want listen, they work in VCL or WMP:
http://fastcast4u.com:9300/
http://96.56.32.46:8002/
http://217.150.130.172:8002/
They can be found at http://www.internet-radio.org.uk/stations/jazz/
What I do is download a .pls file, found in the left side of the site page, and move it into the main window of WMS.
One item is added to Internet-radio folder.
This is the info form:
This is the default test transcoding screen:
Defaul test transcoding.jpg (95.07 KiB) Viewed 17503 times
Although he transcoding, my TV says: file not found.
ramaral wrote:No, i do not use itunes. Why do you ask this?
The folder "Internet-radio" - right click - iTunes radiostations
ramaral wrote: These are examples of radio station what I want listen, they work in VCL or WMP:
Music with transcoding works at all ? (via the folder Transcoding)
ramaral
Contact:
Post by ramaral »
Eugene wrote: The folder "Internet-radio" - right click - iTunes radiostations
I get same error: File not found
Eugene wrote: Music with transcoding works at all ? (via the folder Transcoding)
Yes. I tried a ".ape" file and it works
I don't see any folder named internet radio under the folder transcoder, this is correct ??
Unfortunately, my Sony devices do not have this problem. Maybe other owners Sony TVs have a solution to this problem.
It's correct.
ramaral
Contact:
Post by ramaral »
Eugene wrote:Unfortunately, my Sony devices do not have this problem. Maybe other owners Sony TVs have a solution to this problem.
Maybe my WMS Internet-radio preferences they are wrong ?
When i play a music file or a podcast i see the transcoding progress in the transcoding tab, and an file is created in the transcondig temp folder.
When i play Internet-radio nothing happens - maybe this is the reason for the error 'File not found'
ramaral
Contact:
Post by ramaral »
Hi, Eugene
ramaral wrote:When i play a music file or a podcast i see the transcoding progress in the transcoding tab, and an file is created in the transcondig temp folder.
I would appreciate your comment.
Settings - Additional - Log - turn on Debug
Choose playback a ape-file, choose playback a radiostation, Settings - Additional - Log - View log file - Save
Examine the debug log yourself or send to support@wildmediaserver.com
ramaral
Contact:
Post by ramaral »
I will send to support@wildmediaserver.com
