Pbs.org, c-span.org and ted.org
tech.whiz
Post by tech.whiz »
Can I get script for video podcasts of above mentioned websites? Thanks in advance.
Here are the exact URLs
http://video.pbs.org/
http://www.c-spanvideo.org/videoLibrary/
http://c-span.org/Live-Video/C-SPAN/
http://www.ted.com/
Re: Pbs.org, c-span.org and ted.org
tech.whiz wrote:Can I get script for video podcasts of above mentioned websites? Thanks in advance.
http://www.ted.com/
pbs.zip
(2.28 KiB) Downloaded 831 times
Select the folder PBS - List [Movies] - right click - "Add link" - Path - video page link - Ok
or
Select the folder PBS - right click - "Add podcast" - Link - rss-link - Ok
tech.whiz
Post by tech.whiz »
Thanks Eugene. When should I expect the scripts for C-Span and TED?
samsungfan
Post by samsungfan »
This doesnt seem to work properly for PBS. Is there a way to debug the "script to resource links"?
Zeusx
Post by Zeusx »
I am also very very interested in TED.COM
I hope Eugene can make this possible.
ted.zip
(636 Bytes) Downloaded 866 times
Select the folder TED - List [Movies] - right click - "Add link" - Path - video page link - Ok
Zeusx
Post by Zeusx »
Dear Eugene,
Thanks you so much for publishing the Ted wdf file!
Sadly the TED.wdf didnt work for me.
I added the TED.wdf by dragging the file in the movie list but after executing "update podcasts". No podcasts were updated.
What could be wrong and how can I get it to work properly?
TED is very inspiring to me so I hope you can help.
Zeusx wrote:Dear Eugene,
Zeusx
Post by Zeusx »
Eugene, I think i'm not doing it right.
What do you mean with "video page link"
Zeusx
Post by Zeusx »
Eugene, can get a video one at a time via your advise:
I hope there is a way to get a whole list in one time in there. Please help.
