Links to the problematic media resources
In this topic you can tell about film, music, Internet resources, which are not played through the server using transcoding. For movies, music files, you must specify a reference to a public resource download (torrent, emule, rapidshare) and profile name to use transcoding, for Internet resources - publicly linking to the resource. I will try to suggest a solution.
DEvil HUnter
Re: Links to the problematic media resources
Post by DEvil HUnter »
hi, problem with a video file...
specialy with the audio part:
wild media server tells me the codec is: PCMS16LE
vlc tells me: araw
(video part is mpeg4 (xvid) - no problem with that)
ps: very very nice tool
DEvil HUnter wrote:hi, problem with a video file...
vlc tells me: araw
What is the problem? When transcoding?
DEvil HUnter
the console is opening..
printing some lines of text (about 10 i think).
than exiting..
(about 5times)
seams like an error occures before the real transcoding is starting.
something like can't read audio coding or so. i will try to get a screenshot of it.
DEvil HUnter wrote:the console is opening..
than exiting..
(about 5times)
You can use the test transcoding
DEvil HUnter
seams like the problem is a character encoding problem...
the file has a 'ü' in its name...
(german umlaut)...
so it can't find the file because it interpretes the character in an other way...
maybe depending on the transcoder programm..
DEvil HUnter wrote:seams like the problem is a character encoding problem...
(german umlaut)...
May be help to use short file name, in the beginning transcoding profile
  InputFileName := ExtractShortPathName(InputFileName);
DEvil HUnter
nope - this is not fixing the prob
result string is empty
DEvil HUnter wrote:nope - this is not fixing the prob
Probably off the creation of short names - http://support.microsoft.com/kb/121007/en-us
DEvil HUnter
the key has the value 2..
tryed the value 0 - no effect...
(have win 7 pro)
the path i have problem with is:
i think the problem is the ü as before..
D:\Musik\christina stürmer\videos\Christina Stürmer - Mehr Waffen Video.avi
