I have a quick question!
First, let me explain my setup:
I use Hauppauge HD PVR (image: Component, Audio: Analog)
I use windows media center to record file
I use a PS3 to brodcast
For sure, i use Wild Media server
To be able to see image and sound when broadcastng, i use the TSMuxer-Movies Profile of the latest version (1.08.2 released on DEC 31th)
If i used WTV PS or WTV TS it dosent'work and i received Error code 80040216.
I know that according to this POST, it should not work with TSMuxer-Movies Profile... but it's working for me
Since i record with the hauppauge Device, it's now impossible to ricght-clkick and convert it ot DVR-MS format. I was able to do this with my old Hauppauge 1600 Capture Card
I also noticed that when broadcasting on some WTV files, the file may stop playing for 1 or 2 seconds.
To resolved this, i use the WTV to TS converter from DVR-MS.com. Converted, the file is playing perfectly...
The questions:
1st: Is it normal that my WTV File cannot be played with the WTV PS or TS Profile?
2nd: What can i do to play the WTV file without having the 1 second stop issue? (i would like to be able to play the file without haviong to convert it!)
I have a sample file, please indicate me where i can upload it!
