Hi again,
Is it possible to have a profile for high resolution music (mostly FLAC) format up to 24/192 such as those at
http://www.2l.no/hires/index.html
That does not downsample them? I see wmsmpeg supports 24 bits per sample and also seems to support 192 Khz sampling frequency but if i try duplicating the music/FLAC profile and make a music/FLAC_HIRES profile for 24/192 all I get is pink noise...
Massimiliano
						profile for high resolution music formats
				massimamanno
Re: profile for high resolution music formats
Music Files
Sampling frequency: within 8 - 48kHz (WMA), within 11 - 48kHz
(MP3), 44.1 and 48kHz (LPCM)
Bit rate: Bit rate:within 8 - 320kbps (WMA, MP3), 768Kbps and
1.536Mbps (LPCM)
						BD 390massimamanno wrote: Is it possible to have a profile for high resolution music (mostly FLAC) format up to 24/192 such as those at
Music Files
1.536Mbps (LPCM)
				massimamanno
ops, you're right.
