Folder Structure
Rainer_S
Folder Structure
Post by Rainer_S »
I have some DVD Folders on a USB Harddisk. Unlikely the Structure from these Folders can’t be viewed on my Sony BDP S370. I must go thru many unwanted Folders before i can see the film.
Is there a chance to see the Folders on the Sony Device like the folder structure on the usb harddisk ?
the picture shows an example how complicated the way to the film.
cu
Rainer
TV:Sony KDL 52W4500
Blu-Ray: Sony BDP S370
Sound: Denon AVR 1611
Re: Folder Structure
Folders "Media resource folders" or "Removable Media".
You can turn on the folder "My Computer" (Settings-"Media-Resources")
Rainer_S
Post by Rainer_S »
thanks for the fast answer. is it so easy? iwill try and write a feedback.
have a nice day
rainer
TV:Sony KDL 52W4500
Rainer_S
Post by Rainer_S »
i try this setup. now i see the folder structur,but this isn´t the final step.
i thought,that i can easier start the film, but that is a fault. i know, that i must start the VTS_03_1.vob file. And i know too, that i must change the language into german before i start the film (it is a complicated way,i must go to the audio stream folder and i must run the file 81 to change the language to german
But my wife want be able too, to start a film without the knowing about a dvd structure. Is there a way, to play the dvd from a usb device like a real dvd with dvd menue? Is it a coming feature ,or is that not possible?
With a Mediacenter from Netgear it is possible,and i can start the film with one Click and show a DVD Menue like a real DVD. And i can easy go thru the dvd Menue and play the bonus or change the language with one click.
cu
rainer
TV:Sony KDL 52W4500
Devices do not support DVD-menus in DLNA-mode
