Is there a way to list songs by album track number? I created a playlist that is organized by Genre -> Artist -> Album, and I'd like the songs to be listed by album track number rather than alphabetically. Can this be done without adding the track number to the file name?
List songs by album track number?
Re: List songs by album track number?
Playlist folder - Grouping - mpGenre - mpAuthor - mpAlbum - right click - Edit - "Sort media resources" - mpTrack
If you use the new possibilities of groupingk10ck3r wrote: Is there a way to list songs by album track number? I created a playlist that is organized by Genre -> Artist -> Album, and I'd like the songs to be listed by album track number rather than alphabetically. Can this be done without adding the track number to the file name?
Excellent. Thanks.
Ok, one more question. Is it possible to add an alphabetical grouping of the artists in this structure, similar to the artist index playlist?
Example:
Genre -> Artist (grouped by ABC, DEF, GHI,...) -> Album
Example:
Ok, I figured out how to get close. I added another album layer and manually entered the following for the new album layer:
ReplaceStr((UpperCase(Copy(Trim(mpAuthor), 1, 1))), ",", #13#10)
So, now the structure is:
Genre -> Artist (changed to above script) -> Artist -> Album (sorted by track number)
Ok, one last question and I'll have everything how I'd like it:
Is there a way to apply multiple sort criteria without adding hierarchy?
I would like to list all songs by an artist in sort order: year, album, track number
Select 'ReplaceStr(mpAuthor, ',', #13#10)'
Right click - Add
Expression grouping: 'All songs'
Sort media resources: +mpYear,+mpAlbum,+mpTrack
Right click - Add
Changes in script "Create artist index"
ArtistIndexFolder := WmsFindMediaFolder(mfAudioPlaylistsItemID, 'Artist Index');
if ArtistIndexFolder <> nil then
ArtistIndexFolder.Sort('mpTitle\mpTitle\mpTitle\+mpYear,+mpAlbum,+mpTrack')
finally
WmsHideProgress
Nice! Thanks for your help.
SiriusBlack
Could you document a little better how this can be done?
Screenshots would be helpful.
So I have right-clicked on playlists (Wiedergabeliste), then I have 2 options:
- Add playlist and
- Add folder
Both lead to exactly the same screen:
- I can type a name, that's clear
- then a path (what is this good for?)
- Then pick one of standard, dynamic, transcoding and grouping
- then add a comment
All of that results to just another entry below playlist, but that's it.
Where do I add the mpxxxx stuff?
Do I have to restart the server?
Any help appeciated.
- Add playlist and
- Add folder
