Is it possible to stream meramood.com on DLNA
naveenmah
Post by naveenmah »
Hi!
I like this music site. It has different categories of Indian music
http://meramood.com/
Is it anyway possible to get this on my Samsung TV/Home theater?
Naveen
Re: Is it possible to stream meramood.com on DLNA
naveenmah wrote: I like this music site. It has different categories of Indian music
meramood.zip
(863 Bytes) Downloaded 771 times
2. Choose Music
3. Drag and drop meramood.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Meramood. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file meramood.wdf by right click in the folder tree.
1. IE: open http://www.meramood.com/
2. Right click on selected playlist - Copy shortcut
3. WMS: choose Meramood folder
4. Right click - "Add podcast"
5. Field "Link": right click - Paste
6. Click "Read the properties"
naveenmah
Post by naveenmah »
Hi!
2. Choose Music
Thanks a lot, for quick reply .. will check once I get home ...
Naveen
naveenmah
Post by naveenmah »
Hi
2. Choose Music
I just checked. It works.. It will be really helpfull with some tweaks...
1. It plays some songs but some are not played
I noticed that for many songs file properties are not automatically loaded. If i click on load file property and then try to test transcode then it gives error "missing header" but then plays...
for eg.
http://meramood.net/mp3/2009/3 Idiots - Give Me Some Sunshine.mp3
http://kishorekumarbollywoodmp3songs.com/mp3/2009/3 Idiots - Behti Hawa Sa Tha Woh.mp3
2. When I click on update podcast, it keeps on adding same file again every time podcast is updated.
See screen shot attached for error
naveenmah wrote: I just checked. It works.. It will be really helpfull with some tweaks...
for eg.
I could not reproduce this problem (version 1.05.4).
You can try to use the transcoding profile "Music - Internet-Radio (VLC)"
naveenmah wrote: 2. When I click on update podcast, it keeps on adding same file again every time podcast is updated.
:) , pay attention on column Path (different links)
Fix:
1. Choose Meramood - right click - "Edit Title"
2. List of resources reading script - click "Edit Script"
3.
  AlbumItem, SongItem: TXMLItem;
  SongList: TXMLDocument;
  sPlaylist: string;
  FolderItem.DeleteChildItems;
  SongList := TXMLDocument.Create;
  try
naveenmah
Post by naveenmah »
Hi!
I have version 1.05.1, I guess thats the only version available on the site.
I am still having same issue. After updating podcast, if I play song it gives me error coddec not found
but
if after updating podcast I select all files and click on Load file properties then after that all files play properly.
1.05.4 - http://www.wildmediaserver.com/forum/vi ... f=20&t=578
