Yes, the transcoding profile "Movies (Primary_1920x1080)" converts to frame size 1920x1080.srinivas_av wrote:A general question, Is it possible for WMS To upscale a DVD video while transcoding for HDTV ?
Or is it already doing it if I choose Movies (Primary_1920x1080) profile?
upscaling
Re: upscaling
Re: upscaling
Quality will not be better, typically a media device make it (upscaling) better.srinivas_av wrote:Thank you for confirming.
Can you please also confirm that, upscaling would improve the picture quality ..right?
Re: upscaling
No, unfortunately, from 320x240 you can not do HD quality.srinivas_av wrote:Ok,
Is it possible for WMS, in the future to make it (picture quality) better while at the transcoding stage. I guess, I have enough CPU/memory/GPU power in my desktop which can be utilized. Again, not sure whether it is possible or not technically, just asking.
