Hi, my TV - Panasonic Viera TX-L37D25E - was working great with the latest version of the program. Today I received the following message: (Panasonic Viera TX-L37D25E): 10049: Socket binding error: check the list of the valid connections on the server page.
Well, I did so and I noticed that my TV was not longer seen as active. After doing a search, I saw the ID of the TV changed! That's probably the reason why. When I tried to re-activate it (using the activation code I received the first time) it did not work, even though I noticed that the Devide Code was the same I used for the activation in the first place.
What can I do? This issue has already ruined one evening, I hope it can be solved soon.
I thank you in advance for your support.
Kind regards,
Carlo.
