Hey,
Question, i can not Stream Videos, Pictures and Music works great. I'm using the Trial to stream my files to an BDP S570 Sony.
I get always a message. File not supported, something like this. How can help me to get it in run ?
Thomas
Streaming Problem BDP S570 Sony
Re: Streaming Problem BDP S570 Sony
You can try the configuration "DLNA Device (version 1.5, 16:9, 720x406)"; http://www.wildmediaserver.com/forum/vi ... &f=3#p3473thotrix wrote: Question, i can not Stream Videos, Pictures and Music works great. I'm using the Trial to stream my files to an BDP S570 Sony.
Ok, i installed the upgrade. Do I need to transcode the movies in advance or we I get on my disc player?
When I open the folder, not supported file format. Pictures and Music works great.
I need Help to get my Videos in Run.
Try upgrade firmware or use navigation via Transcoding folder.thotrix wrote:Ok, i installed the upgrade. Do I need to transcode the movies in advance or we I get on my disc player?
The Files ( Movies ) in the Transcoder Folder are aslo not working. As the films get into it, I need to do this manually?
"not working" for all files ?thotrix wrote:The Files ( Movies ) in the Transcoder Folder are aslo not working.
Profile :Sony BDP DLNA 16:9 720 x 406
DLNA 1.5 is marked.
It's have AVI and MKV files
DLNA 1.5 is marked.
Files are played via USB ?thotrix wrote:It's have AVI and MKV files
I try tonight, just reformat an external hard drive to test a few things can be. Maybe it's all even with the update. Can not test right now.
It's not working! I can see the Files in the Transcoding Folder with a (T) before. If i try to get it in run, i get a message There is no playable file.
