This topic is invited to publish the localization files for installer
Main module installation (English, Russian)
Module for unpack distribution kit (English, Russian)
Bonus: 1 free licence
Editing wln-files
Help - Language - Localization - Load - choose file - "Loading mode" - "Open specified file"
Localization Setup
Re: Localization Setup
Hello Eugene,
see the french translation for both files into zip.
- wmssetupsfx.zip
- (2.5 KiB) Downloaded 2963 times
- wmssetup.zip
- (8.6 KiB) Downloaded 2837 times
Hi m8
Have the romanian translation.
Cheers
Cheers
- romanian wmssetupsfx.rar
- (1.13 KiB) Downloaded 2906 times
- romanian wmssetup.rar
- (3.55 KiB) Downloaded 2922 times
S@gittarius
This is Bulgarian localization for setup files.
Apart from translating I found no way to load and test them. Is it possible with the current distribution?
Regards
Regards
- wmssetupsfx_bg.zip
- (1.24 KiB) Downloaded 2862 times
- wmssetup_bg.zip
- (3.71 KiB) Downloaded 2804 times
Hi
Thanks (and +1 licence). From form "Program localization" you can "Save As" setup.sln & setup_ws.sln.S@gittarius wrote: This is Bulgarian localization for setup files.
S@gittarius
Hi,Eugene wrote:HiThanks (and +1 licence). From form "Program localization" you can "Save As" setup.sln & setup_ws.sln.S@gittarius wrote: This is Bulgarian localization for setup files.
Still no success here.
I saved the files as described in the installation path and the only thing that happened was language in setup program changed from English to Russian.
There is still no way to select an alternative localization for the setup utility. Is there?
Regards
Copy setup_ws.sln to directory with setup_ws.exe
Choice language automatic only
Only Bulgarian translation Copy setup.sln to ?:\Program Files\Wild Media ServerS@gittarius wrote:Hi,Eugene wrote:Thanks (and +1 licence). From form "Program localization" you can "Save As" setup.sln & setup_ws.sln.S@gittarius wrote: This is Bulgarian localization for setup files.
S@gittarius
Hi,Eugene wrote:Hi,Copy setup.sln to ?:\Program Files\Wild Media ServerS@gittarius wrote:Hi,Eugene wrote:Thanks (and +1 licence). From form "Program localization" you can "Save As" setup.sln & setup_ws.sln.S@gittarius wrote: This is Bulgarian localization for setup files.
I think I could figure it out.
Currently only one language is loaded by the setup program and when the localization is to be saved only the one of an interest has to be written. Then placed into the installation directory. Right?
Regards
S@gittarius
Minor fixes after a real tests in setup utility.
Regards.
Regards.
- setup_bg.zip
- (3.77 KiB) Downloaded 2870 times
- setup_ws_bg.zip
- (1.24 KiB) Downloaded 2755 times
Hi Eugene
Translation in polish language
