i have a problem with playing podcasts on my sony TV. First time everything is ok, but the second time the podcast is not working anymore and i have to restart WMS (WMS 1.04.7) if i want to watch it again.
I can do Test transcoding as often i want and its ok. But when i've played it the firts time on my tv its not working anymore
Here are the console outputs of the two scenarios:
1. test transcoding before sony (i tried it 5 times)
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "\\.\pipe\903CBCEEE0D34F4C9
6F85912617857E" -f dvd -vcodec mpeg2video -b 9000000 -aspect 16:9 -copyts -pix
fmt yuv420p -r 25.000 -threads 6 -acodec ac3 -ab 448000 -ar 48000 -ac 2 "C:\wil
ms\WmsTemp\Test_5d5ce617bc1aaee71d65d831b3e22a70.mpg" -v -1 -loglevel quiet
built on May 2 2010 17:40:51 with gcc 4.4.0
libavutil 50.13. 0 / 50.13. 0
libavcodec 52.61. 0 / 52.61. 0
libavformat 52.57. 1 / 52.57. 1
libswscale 0.10. 0 / 0.10. 0
[flv @ 002595f0]Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1)
-> 25.00 (25/1)
Input #0, flv, from '\\.\pipe\903CBCEEE0D34F4C946F85912617857E':
Metadata:
duration : 60
starttime : 0
totalduration : 60
width : 640
height : 360
videodatarate : 791
audiodatarate : 96
totaldatarate : 888
framerate : 25
bytelength : 6664696
canseekontime : true
sourcedata : B4A7DAB43HH1282203847608404
purl :
pmsg :
Duration: 00:00:59.52, start: 0.000000, bitrate: 809 kb/s
Stream #0.0: Video: h264, yuv420p, 640x360 [PAR 1:1 DAR 16:9], 809 kb/s, 50
fps, 25 tbr, 1k tbn, 50 tbc
Stream #0.1: Audio: libfaad, 44100 Hz, 2 channels, s16
Output #0, dvd, to 'C:\wildms\WmsTemp\Test_5d5ce617bc1aaee71d65d831b3e22a70.mpg
: Video: mpeg2video, yuv420p, 640x360 [PAR 1:1 DAR 16:9], q=2-31, 9000 kb/s, 90
tbn, 25 tbc
: Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
Press [q] to stop encoding
frame= 1489 fps= 67 q=1.6 Lsize= 46808kB time=59.52 bitrate=6442.4kbits/s
2. test transcoding after sony
"C:\Program Files\Wild Media Server\wmsmpeg.exe" -i "http://v3.lscache4.c.youtub
e.com/videoplayback?ip=0.0.0.0&sparams=id%2Cexpire%2Cip%2Cipbits%2Citag%2Calgori
thm%2Cburst%2Cfactor%2Coc%3AU0dXR1JNVF9FSkNNN19KR1hF&fexp=902905&algorithm=throt
tle-factor&itag=34&ipbits=0&burst=40&sver=3&expire=1282226400&key=yt1&signature=
CCEE88EE7D1D33889867448C039A05B4184F5EAF.1A0531A3650DDF6D680D6701F8F5776F4531841
C&factor=1.25&id=80afd58d02cacf17" -f dvd -vcodec mpeg2video -b 9000000 -aspect
16:9 -copyts -pix_fmt yuv420p -r 25.000 -threads 6 -acodec ac3 -ab 448000 -ar 4
8000 -ac 2 "C:\wildms\WmsTemp\Test_5d5ce617bc1aaee71d65d831b3e22a70.mpg" -v -1 -
loglevel quiet
http://v3.lscache4.c.youtube.com/videoplayback?ip=0.0.0.0&sparams=id%2Cexpire%2C
ip%2Cipbits%2Citag%2Calgorithm%2Cburst%2Cfactor%2Coc%3AU0dXR1JNVF9FSkNNN19KR1hF&
fexp=902905&algorithm=throttle-factor&itag=34&ipbits=0&burst=40&sver=3&expire=12
82226400&key=yt1&signature=CCEE88EE7D1D33889867448C039A05B4184F5EAF.1A0531A3650D
DF6D680D6701F8F5776F4531841C&factor=1.25&id=80afd58d02cacf17: Error number -5 oc
curred
KDL-37V5800 - Problems with Podcasts
Re: KDL-37V5800 - Problems with Podcasts
WMS does not receive a response from the server Youtube, why is unknown. Try the latest versions of WMS, possible changes.benschy wrote: i have a problem with playing podcasts on my sony TV. First time everything is ok, but the second time the podcast is not working anymore and i have to restart WMS (WMS 1.04.7) if i want to watch it again.
-> 25.00 (25/1)
Metadata:
duration : 60
starttime : 0
totalduration : 60
width : 640
height : 360
videodatarate : 791
audiodatarate : 96
totaldatarate : 888
framerate : 25
purl :
pmsg :
tbn, 25 tbc
Stream mapping:
Stream #0.0 -> #0.0
Stream #0.1 -> #0.1
loglevel quiet
http://v3.lscache4.c.youtube.com/videop ... Cexpire%2C
curred
no, the latest update has not fixed my problem.
Why is the console parameter changed after my tv accesed the file??
From -i "\\.\pipe\903CBCEEE0D34F4C96F85912617857E" --> to --> -i "http://v3.lscache4.c.youtube.com/videop ... ipbits%2Ci ......
Thanks Ben
Thanks Ben
WMS does not receive a response from the server Youtube for creating "\\.\pipe\..."benschy wrote: no, the latest update has not fixed my problem.![]()
THX for your fast reply! This problem occurs not only for youtube, it occurs for all my video podcasts
All other functions of WMS are working perfekt! Thx for this great mediaserver!
Ben
Ben
Maybe fixed in 1.05rc5benschy wrote:THX for your fast reply! This problem occurs not only for youtube, it occurs for all my video podcasts![]()
