Page 1 of 2
Romanian translation
Posted: Wed Aug 04, 2010 12:29 pm
by gugu
Here you have the romanian localization for 1.04.7.
Also the file MediaInfo/MediaInfoRo.csv has to be replaced with the one supplied (more complete and better translation, I reckon ;) )
Work on the wms_ro.chm is on the way. Should be done in a couple of days.
Cheers,
gugu
Re: Romanian translation
Posted: Wed Aug 04, 2010 5:49 pm
by gugu
I cant figure out what next means:
"For catalogs photos have the opportunity to select the source date media resources (Auto, creation date, modification date, metadata), Auto - if there is no metadata, the date of modification. Selection on right click "mouse" in the directory list of media resources (column photo). "
Cheers
Posted: Wed Aug 04, 2010 6:35 pm
gugu wrote: I cant figure out what next means:
Unfortunately the choice had disappeared in version 1.04, picture from 1.03
This setting allows the user to specify what data is displayed in column "Create date" after scanning.
Posted: Sun Aug 08, 2010 1:38 pm
by gugu
Here you have the updated romanian localization for 1.04.7.
Also the wms_ro.chm.
Of course you can include all three files into the distribution kit. I have no problem with that.
Unfortunately I can't Private message you the email address as composing a private message is forbidden for me, and I'm reluctant to publicly post the email in the forum.
If you have a solution for that please let me know.
Cheers
Posted: Sun Aug 08, 2010 1:45 pm
by gugu
It looks that I can't ul files more than 256 KB.
wms_ro 1.04.7.zip has 2.59 MB :(
Cheers
another 3
Posted: Sun Aug 08, 2010 1:51 pm
by gugu
Another 3
Cheers
Last 2
Posted: Sun Aug 08, 2010 1:52 pm
by gugu
Last 2
Cheers
Posted: Sun Aug 08, 2010 2:42 pm
gugu wrote: Also the wms_ro.chm.
Romanian help file http://www.wildmediaserver.com/files/Help/wms_ro.chm
gugu wrote: Of course you can include all three files into the distribution kit. I have no problem with that.
Ok, now I know that they are ready :)
gugu wrote: Unfortunately I can't Private message you the email address as composing a private message is forbidden for me, and I'm reluctant to publicly post the email in the forum.
Users use private messages to me, perhaps there was a problem with the transition from https:// to http:// - lost authorization. In any case, you can use support@wildmediaserver.com, info@wildmediaserver.com.
Posted: Mon Aug 09, 2010 8:43 am
by gugu
Some other files.
Cheers,
Posted: Mon Aug 09, 2010 1:50 pm
gugu wrote:Some other files.
Great, but I think, mistake with archive.
