Megavideo and WMS
carnero
Megavideo and WMS
Post by carnero »
Hi all,
Is there any way to wach megavideo movies on de Wild Media Server? (Like youtube or others steams).
for exemple: http://www.megavideo.com/?v=8ZBD4AP6
I can add the link on WMS, but how can I wach on my TV?
follow the print with the transcode test.
Thanks for the support, and for the best software ins DLNA/UPnP services.
att.
Carnero
Re: Megavideo and WMS
Hi
carnero wrote: Is there any way to wach megavideo movies on de Wild Media Server? (Like youtube or others steams).
There is a version
megavideo.zip
(1.5 KiB) Downloaded 1721 times
2. Drag and drop megavideo.wdf from Explorer to main form of program.
If the loading is successful, then in Podcasts folder appear Megavideo. If the folder does not appear (Windows 7, Windows Vista), then the program and Explorer are running with different rights. Try to load the file megavideo.wdf by right click in the folder tree.
"Add link" on right click mouse
For owners Premium account
1. Open video page (login required) in IE.
2. On right click "View source"
3. Ctrl + F: flashvars.userid =
4. Copy userid to clipboard.
5. WMS - Megavideo - right click - Edit title - "Script for the links to the resource" - Edit script - paste your userid in line csUserID = ''; between '
carnero
Post by carnero »
It works!
I realy appreciate your help. WMS is the best software ever!
Ty.
Carnero
paltibet
Post by paltibet »
Hello
I am testing WMS and it works really well.
About Megavideo, I did follow all the Eugene's instructions but it didn't work, I could not load the example video.
I tested MTV and it works perfect and I follow the same way.
Thanks and sorry for my english
carnero
Post by carnero »
Try to use this settings.
carnero
Post by carnero »
Everything is working perfectly, but megavideo do not allow you to watch more than 72 minutes/movie.
Only who have premiun Megavideo acc. can watch more than 72 min. I have a premium acc. for megavideo. How can I use my ID on WMS?
Thank you in advance.
Carnero
carnero wrote: Everything is working perfectly, but megavideo do not allow you to watch more than 72 minutes/movie.
May be simply not to do "Sign out"
carnero
Post by carnero »
Eugene wrote:Hi,
Its not working. any other way?
carnero wrote:
Eugene wrote:Hi,
There are example of link to check ?
paltibet
Post by paltibet »
carnero wrote:Try to use this settings.
Thanks carnero
I got the podcast chanell but when I try to do update podcast it does nothing. I tested your example link and other one
