search in localization
it is possible tou add a search fonction in localization tabs?
Re: search in localization
Ctrl+Flecureuil wrote:it is possible tou add a search fonction in localization tabs?
Search & replace would be better as a better search (something that makes possible to search for ", " )Eugene wrote:Ctrl+Flecureuil wrote:it is possible tou add a search fonction in localization tabs?
