script loading information for filmaffinity (database of fil
cginer
Post by cginer »
Interested on using filmaffinity.com/es web in order to obtain movie information
Could anybody indicate which should be the script loading information in settings database of films?
Thank you very much
Re: script loading information for filmaffinity (database of fil
cginer wrote:Interested on using filmaffinity.com/es web in order to obtain movie information
filmaffinity.zip
(1.2 KiB) Downloaded 513 times
1. Unzip.
2. On right click mouse "Edit information".
3. Click "Search on websites IMDB..."
4. Click load, filmaffinity.cfg, "Clear the current lists ?" - No.
Search engine does not understand Unicode-encoded characters, so names containing national characters must be found manually.
cginer
Post by cginer »
Excellent! Thank you very much
Is it possible to view the whole media resource information while navigating in sony tv o similar connected with dlna as it can be done in xmbc?
Do not find something similar in forum. Hope not too much questions
cginer wrote: Is it possible to view the whole media resource information while navigating in sony tv o similar connected with dlna as it can be done in xmbc?
Navigation via Transcoding folder, folder "Information from the Internet media database".
cginer
Post by cginer »
I've found it
I'm going to try it.
Thank you very much
Impressed for such a hot line support.
